Clock setting with Nav
Old Nov 15, 2007 | 10:28 AM
fiddlefadel's Avatar
Default Clock setting with Nav
With the daylight savings time change recently, my clock (with nav) now reads a hour late. I have the correct time zone and the daylight savings enabled. If I disable the daylight savings, the time is correct.
I can not find any way to adjust the time! The only adjustment I have found is the above. Am I not findings the adjustment for time setting or is there none. I called my Mits dealer and asked them, and he said they had little experience with them, and I had to drive the car to them to see if they could find an adjustment before they contacted Mits tech.
thanks
Dave
Old Nov 15, 2007 | 11:23 AM
brian360's Avatar
Default RE: Clock setting with Nav
As far as I know the time is updated from the GPS satellites -- the only control you have over the time is the time zone and whether DST is Active or Inactive. Note that the DST option doesn't mean "Automatically adjust for DST" but it means "Is the timezone currently observing DST right now or not", so you do have to manually tick that option on or off as needed.
Old Nov 15, 2007 | 12:05 PM
tdford's Avatar
Exactly what brian360 said, the GPS sets the clock to the time zone that you select. Then its a matter of turning DST on or off. That should be all you need. My clock is always the same as my cell phone, so Im taking its accurate.
My only guess is that you would like it to read "early" or "late", for your own purposes...
Old Nov 15, 2007 | 03:24 PM
antlip's Avatar
Yea go into the options and turn off or on day lights savings. That will put you back or forward the hour you need. I got in my outlander and thought it was odd that it didnt change with the time but I just switched the day light savings option and it was correct.
Old Nov 15, 2007 | 04:29 PM
Thanks all for your responses! I thought that the time was GPS adjusted. I currently am in daylight savings (Nov 4th) and as I mentioned it moved my time forward an hour instead of backward an hour and when I disable the daylight savings, it gives the correct time. Do you think there is an error with the programming?
thanks again
Dave
Old Nov 15, 2007 | 04:39 PM
brian360's Avatar
It didn't move your time forward an hour, it simply didn't adjust it back an hour automatically. It is not designed to automatically adjust for daylight saving time, you have to enable/disable it manually twice per year. So come spring time, you will have to go into the options menu again and re-enable daylight saving in order to move it one hour forward for the time change again. Sounds like your navigation system is working perfectly.
Old Nov 15, 2007 | 08:36 PM
antlip's Avatar
No its not broken your fine.
rbgiantfan
Dec 30, 2013 06:09 PM
shawark
Mar 19, 2010 02:55 PM
mightyOUTTIE
May 5, 2008 02:40 PM
tufduck
Sep 8, 2007 01:00 PM
99clipsgst
Apr 2, 2007 07:55 PM
