For Curt hitch owner FYI
Roach,
Thanks again for the info.
Is your wiring harness attached to the bumper or the hitch? It looks wedged in there.
I'm gonna go ahead and order mine this weekend, along with the harness, mud guards, cargo cover, and trunk mat.
ORIGINAL: Cuffy
Roach,
Roach,
Roach,
Did you use a torque wrench to tighten down the bolts when you installed your hitch?
Or just brute force?
I don't have a torque wrench at home and don't want the hitch to wiggle loose if that's required. I do plan to put some lock washers on it to keep the bolts tight.
ORIGINAL: Cuffy
Roach,
Roach,
ORIGINAL: Fisherman
I noticed mine was showing a fair amount of rust already as well. Maybe I will look into this. Worst case, I take it off and get it powder coated.
ORIGINAL: Fisherman
You purchased yours from Etrailer.com didn't you? That's where i was going to get mine from, but if yours is rusting I may not.
When you installed yours did you use a torque wrench?
Thanx
ORIGINAL: roach
If you bought it from a local shop you should go back and have them to take a look at it they may replace it same as what Happen for me.
ORIGINAL: Fisherman
ORIGINAL: Cuffy
Fisherman,
Thanx
ORIGINAL: Fisherman
Thanx
Yes - I use a torque wrench.
I looked at the Curt Manufacturing Inc website and they comment that one of their key features is a powder coat paint process that resists rusting. I guess they need to update their process. Hopefully it's just one production run of hitches that had bad paint.
Fisherman, did you contact Etrailer about the rust issue? If so what did they say? (Call Curt Manuf for warranty issues probably).
