Dead display for radio
Hi
I have a problem with my original radio (radio and cd player - not multi cd player or nav head unit) in my Outlander from 2008. There are no light in the display and the buttons do not work. The radio is still able to play and the volume and so on can be adjusted by the buttons on wheel.
Hope that any one do have a solution to fix this problem.
Based on what I found in the service manual, the panel assembly that houses the display has to be replaced and it's around $620 to $630, new.
Those go for pretty cheap on eBay, its just plug and play...just get on for a Lancer/Outlander/RVR they are the exact same units. I believe they changed them in 2009 to support the new wireless bluetooth streaming/USB in (FUSE).
It'd be great if folks could pull the LED display module itself and swap it out with one that works. Or is that sucker a permanent part of the panel assembly?
I realize that this is probably a "nice idea" at best but it can't hurt to think along those lines.
It doesn't sound like the display is the issue here. Since it was functional for a brief second, either that means the MMCS has failed, or the driver for the display. Better practice to replace the whole thing.
Oh yes. Sorry. I was thinking of someone else's display problem.
