RE: Dealer says Synthetic ONLY - 1st oil change
What oil brand do you guys think is the best to use ?
Mobil 1
I would recomend you to switch synthetic if you dont mind the extra $20 or so. A lot of people think its pointless to use synthetic if you have to change it at 3500/3months anyway, but the true quality of synthetic oil comes in the form of being able to maintain its chemistry even at high/cold temperatures. A perfect example would be if you do a lot of long distance driving were you car is running at a verry warm temperature constantly, conventional oilwill do just fine, bud its protective capabilities are reduced the longer it runs at higher temperatures, synthetic however remains constant through outany temperature range. So 20 bucks seems reasonablefor that extra peace of mind. I will not get into the typical argument that usually arises during theseconventionalvs syntheticssubjects but I will tell the $ is well worth it in the long run if you plan to keep that car. Now if you plan on trading in or selling, dont use synthetic because you will never see the fruits of your crops.
Lots of good brands of oil...
Mobil1 is good, but they changed back to Group III stock, whichstarts from oil, but is refined and hydrocracked.I love the hyprocrasy as Mobil sued Castrol for for claiming Syntec (Group III)was syntheic. I'll run through my stash of M1 and will likely switch to Pennzoil Platinum because I don't care for Exxon/Mobil as a company |
Mitsubishi UK use synthetic oilafter the 2nd oil change same with my 54 reg shogun sport
puddy |
They ended up using Mobil 5000 which is dino oil not synthetic. The first 3 are free at my dealer, but after that they want $40/oil change. That seems high to me. I've always used regular oil, not because i'm partial to it or anything...i just could never see spending $50+ every 3500 miles.
Since there regular oil change price is high, I may just buy a case of synthetic for $30 and see what they'll charge then. |
You can get 5 qt jugs of synthetic oil (Mobil1, Pennzoil Platinum, Syntec...) at WalMart for under $25
in the UK when I owned my cars i always took my own oil and oem filter for them to use at service time use to supply my own spark plugs and air filters too. why pay retail for partsat service invoice timewhen i used to get trade prices on all my parts i just paid for labor only
now i lease my cars |
