Detailed Rear Camera Installation
Old Jun 25, 2012 | 10:26 PM
  #181
Vadimus's Avatar
Originally Posted by dej73
hi vadimus!!! I ordered just like your back up camera and the mirror last june 13, 2012 and am still waiting for the items, how many weeks to ship or mail those items?// thanks!!!
Do not remember exactly, around 2-3 weeks.
Old Jun 26, 2012 | 08:24 PM
  #182
dej73's Avatar
I just got the camera and still waiting for mirror or monitor!!! thanks vadimus!!!!
Old Jun 26, 2012 | 08:29 PM
  #183
Vadimus's Avatar
You're welcome
Let me know if you need help with installation.
Old Jun 27, 2012 | 09:54 PM
  #184
dej73's Avatar
You're welcome
am okay vadimus, i just installed already but the camera little bit loose on my pre cut plastic trim so i put litte glue/adhesive, hopefully will hold on it. After installed i just used my dvd player w/ monitor to test, it so clear and color too thats nice!!! I dont see the line on the monitor or TV maybe the other one that still waiting for the monitor.... bye,thanks!!!
Old Jul 3, 2012 | 02:54 PM
  #185
dej73's Avatar
You're welcome
hi vadimus! I got the monitor last friday and easy to install, the power just tapped to reverse light but every time you put on the reverse you will see i think 3 different setting like first one without lane warning then next v1PAL with lane warning sign and last one v1NTSC with lane warning sign. I like the last setting more bright and clear. How can i set into one setting only? i try to press the 3 button on the back but nothing....pls help me???
Old Jul 3, 2012 | 08:56 PM
  #186
Vadimus's Avatar
My cam starts as a PAL with no lines, next R-N-R shift makes it work in NTSC with lines.
I am going to find out how to change this to NTSC/no lines - lines doe not take into consideration the fact that camera is both shifted and tilted. Besides, at night bright lines decrease overall image contrast.
My camera is connected to AV2 as it has priority over AV1 (if both are active same time AV2 is shown).
For me it does matter as I occasionally connect AV1 to my BlackVue dashcam.
Buttons on the back of the mirror are +, Menu, -.
I'd recommend to increase brightness/contrast to help image be visible in a bright sunlight.
Old Jul 4, 2012 | 06:30 AM
  #187
dmagic17's Avatar
Finally got this in - Ended up picking up this rear view mirror Amazon.com: Boss Audio BV4.3RM Rear View Mirror: Car Electronics. It's a full replacement for the mirror and I think looks pretty OEM.
Then I used the camera you recommended and tossed the crap one the mirror came with.
Thanks for the help Vad
Old Jul 4, 2012 | 08:58 AM
  #188
Vadimus's Avatar
You're welcome
Do you still have a factory mirror, BTW?
If so, what do you think about selling it?
Old Jul 4, 2012 | 11:22 AM
  #189
dmagic17's Avatar
You're welcome
Hmm I'll probably hang on to it just in case, but I'll let you know if I change my mind.
Old Aug 6, 2012 | 12:02 PM
  #190
Mario Griffin's Avatar
Great Thread!! Will try it...
