Dia Queen ATF substitute?
My 07 Outlander is coming due for a transmission fluid change. I was surfing the net for Dia Queen and came across ENEOS Transmission Fluid ATF
If you click on the attached link you will see charistics and properties. It says that it is a direct replacement for the Dia Queen. It is also a lot easier on your wallet. I know that there may be other substitutes that may be safe to use but I am curious if this may be safe to use on my outlander. If I have to pay top dollar for Dia Queen......so be it. Its a lot cheaper then replacing my transmission.
Nippon Oil | ENEOS ECO-ATF
MitsubishiDiaQueen ATF SP-II...Yes
DiaQueen ATF SP-III........Yes
DiaQueen ATF II.............Yes
DiaQueen ATF AW...........Yes
DiaQueen CVT Fluid J1......NO
DiaQueen ATF SK............Yes
Thanks ben. I will do more research.
