DIA Queen J2 shower
Old Jun 19, 2012 | 12:01 PM
  #31
ryandlor's Avatar
Originally Posted by MM3Canuck
To clear things up for everyone:
When removing the upper hose from the tranny cooler:
1. You will only get a drop or two from the removed hose.
2. The upper nipple (the one with the removed hose) will pump out fluid if engine started.
3. Place a hose over the nipple and direct into a container.
4. Run engine in 'N' (neutral) - I ran mine for about 30-45seconds. ~ 3.8-4 liters came out
5. Shut off after 30-45 seconds
6. Drain the remaining fluid via drain bolt. ~ 0.8 liters
Thanks Canuck,
Tranny run smoother now?
Old Jun 21, 2012 | 01:40 PM
  #32
MM3Canuck's Avatar
Originally Posted by ryandlor
Thanks Canuck,
Its like changing engine oil, you dont feel a difference.
My change was at 50,000km, it wasnt too bad yet. But I doubt that even at 100,000km you would feel a difference. - All in your head!!!!
Old Jun 2, 2013 | 03:04 PM
  #33
jsrd's Avatar
This weekend I replaced the transmission oil in my 2007 Out with 55,023 km by following the instructions in the forum have shared, and were a great help ...
Here in Mexico the dealer does not sell the Dia Queen J2 oil so the first step was to buy in the United States.
1. I removed the tire.
2. I removed the splash guard
3. I removed the upper hose and put a hose in the free port of the oil cooler
4. I drained the oil, I expected that oil out in extra hose, but nothing came out, this was a surprise to me. The oil was of a brown color and cloudy, so it was a good decision to make this work, because the maintenance manual suggests at 9 years for this
5. I removed the drain plug from the bottom of the transaxle case to drain more oil, but this was my second surprise, because it came out nothing
6. I fill with a new oil (7 bottles) and repeted the extraction oil process until it started to get out of a beautiful red color, and then I did a travel to raise the recommended temperature and adjust the level in dipstick on H mark
7. Finally went back to put the splash guard and the tire
Attached Thumbnails DIA Queen J2 shower-imagen1.jpg   DIA Queen J2 shower-imagen2.jpg   DIA Queen J2 shower-imagen3.jpg   DIA Queen J2 shower-imagen4.jpg   DIA Queen J2 shower-imagen5.jpg
Old Jun 3, 2013 | 02:29 PM
  #34
OutlanderGT's Avatar
Good Job jsrd!
PeckyPeck
Nov 30, 2014 03:31 PM
Broncoman75
Apr 25, 2012 02:26 PM
nesser
Mar 13, 2012 08:55 PM
GREG
Sep 21, 2011 05:54 PM
ronsin1
Jul 27, 2009 11:03 PM
