Disable TPMS light
In an Outlander 2010 XLS, how can we disable the TPMS light
I tried the pressurize can an it dosent work. Now, i put a piece of black tape on my plastic glass cuz i dont know how to remove the bezel and the dash. Can someone help me ?? |
you mean the tire pressure that too low ?
if so, well after you put air, you might have to drive a few KM for the light to go away with the proper pression on the tire. |
the tpms are not in my wheel and i'm sure i can find something to disable the light in the dash
cut a wire or something like that |
Its actualy a wireless sensor good luck to disable it
if i want to disable the LIGHT in my dash ?
the tpms is a bulb or a led in the cluster ? i'm sure there is a wire who control the tpms light in cluster |
The TPMS light on the dash is a SMD LED, which requires you to de-solder it in order to get rid of the light.
Would it not be easier just to put 4 TPMS modules into your tires?
put some air in and drive, that's all you need to disable the light. it will go off when it detects the air pressure is higher than around 26-28psi
Just hold in your info button for a few seconds and it will reset. Only thing is you have to do it every time you start the vehicle.
Look here elerico https://mitsubishiforum.com/forum/sh...ighlight=tpms; (step 2 isn't necessary) the pics is lost but tcp's explanation is easy to follow. . .
