Disable TPMS light
Old Sep 13, 2010 | 11:34 AM
elerico's Avatar
Default Disable TPMS light
In an Outlander 2010 XLS, how can we disable the TPMS light
I tried the pressurize can an it dosent work.
Now, i put a piece of black tape on my plastic glass cuz i dont know how to remove the bezel and the dash.
Can someone help me ??
Old Sep 14, 2010 | 02:48 PM
armymen's Avatar
you mean the tire pressure that too low ?
if so, well after you put air, you might have to drive a few KM for the light to go away with the proper pression on the tire.
Old Sep 15, 2010 | 06:45 AM
elerico's Avatar
the tpms are not in my wheel and i'm sure i can find something to disable the light in the dash
cut a wire or something like that
Old Sep 15, 2010 | 06:49 AM
armymen's Avatar
Its actualy a wireless sensor good luck to disable it
Old Sep 15, 2010 | 03:54 PM
elerico's Avatar
if i want to disable the LIGHT in my dash ?
the tpms is a bulb or a led in the cluster ?
i'm sure there is a wire who control the tpms light in cluster
Old Sep 15, 2010 | 05:42 PM
ivanz's Avatar
The TPMS light on the dash is a SMD LED, which requires you to de-solder it in order to get rid of the light.
Old Sep 15, 2010 | 06:01 PM
rip14's Avatar
Would it not be easier just to put 4 TPMS modules into your tires?
Old Sep 16, 2010 | 10:25 AM
ark_royal's Avatar
put some air in and drive, that's all you need to disable the light. it will go off when it detects the air pressure is higher than around 26-28psi
Old Nov 6, 2010 | 06:34 PM
JudoWiz's Avatar
Just hold in your info button for a few seconds and it will reset. Only thing is you have to do it every time you start the vehicle.
Old Nov 6, 2010 | 08:04 PM
jsrd's Avatar
Look here elerico https://mitsubishiforum.com/forum/sh...ighlight=tpms; (step 2 isn't necessary) the pics is lost but tcp's explanation is easy to follow. . .
