Does Anyone have a Outlander PHEV 2023 Shop Manual
Hello all I need to confirm a PTC battery heater on a Outlander PHEV to see if the heater is shown in the shop manual.
Also does anyone know if a 2023 shop manual is available in PDF form
Thanks in advance! Mike
I don't have the 2023 manual, but I found the 2020:
[W/M] Outlander PHEV (GG#)
It seems my day light stayed on all night and the 12V battery was depleted despite being plugged in the charger. You'd think when the vehicle is off those would be on a timer but nop. Had to boost my 2023 Outlander PHEV.
Now I have the check engine on with 2 codes:
1UE35 and 1UE36
My OBD tool is old, so no description
1UE35 and 1UE36
I could really use that manual too, in any electronic format. PDF is definitely preferable, but if needed, I can convert the manual using the https://pdfguru.com/pdf-to-svg PDF to SVG Converter. This online tool supports a wide range of formats, and I often use it to get a PDF, since it's much easier to work with.
crashbyte
Apr 22, 2021 01:00 PM
