Dome Light
Dome Light
Hi,
What is the bulb number for the dome light. My has blown and went to AutoZone for a replacement, but they do not list a part number for it. Owners manual just says 8W bulb.
The bul's only marking is A12V8W.
thxs
J
thxs
J
31MM lenght 12V/8W, which apparently are virtually non existent in the aftermarket. I found lots of LED alternatives, so I guess I'll just convert to an LED.
i am using the third one down for the dome light, the 3022, $10 one, very bright, for the license plate, i use the first one, but too bright, easy to see my numbers, i don't like it.
http://www.autolismo.com/led.html
look at these 12 led system, I use them & are excellent
http://store.ijdmtoy.com/Luxer1-12-L...anel_sku53.htm
LED | Autolismo
LED | Autolismo
was it the first one under here:
Festoon Bulbs | Autolismo
thanks
Dear outie friends
Yesterday i replaced my 2008 outie dome lights to white leds and ive got a problem:
the leds are working graet when the doors r open,but when i closed the doors and after a while the leds r fading out and iwant to open the lights with the dome light switch to on-the lights from the leds r very weak.
another try to open the doors they lights bright and ok.
i change last week the car batterry to a new one.
what can cause this problem???
tnx a lot
tnx a lot
I used these in my 2007 Outlander. They work great.
3022-xHP4 High Power LED Festoon Bulb Specifications
