Dome Light
Old Sep 8, 2009 | 04:01 PM
joeba's Avatar
Default Dome Light
Hi,
What is the bulb number for the dome light. My has blown and went to AutoZone for a replacement, but they do not list a part number for it. Owners manual just says 8W bulb.
The bul's only marking is A12V8W.
thxs
J
Old Sep 9, 2009 | 09:28 AM
joeba's Avatar
Originally Posted by joeba
Hi,
thxs
J
I should of added this is for a 2007 Outlander. It looks like it's a Festoon based buld of
31MM lenght 12V/8W, which apparently are virtually non existent in the aftermarket. I found lots of LED alternatives, so I guess I'll just convert to an LED.
Old Sep 18, 2009 | 05:55 PM
brianwis's Avatar
Hey Joeba
What type of LED dome light did you buy and where did you get it from. I've been looking to replace all the interior lights with white LED's.
Thanks in advance.
Old Sep 19, 2009 | 02:15 AM
VancouverMitsu's Avatar
i am using the third one down for the dome light, the 3022, $10 one, very bright, for the license plate, i use the first one, but too bright, easy to see my numbers, i don't like it.
http://www.autolismo.com/led.html
Old Sep 19, 2009 | 06:42 PM
klas's Avatar
get vleds from vleds.com if you want the brightest one. They have 2 watt ones for $11
Old Sep 27, 2009 | 10:08 AM
dger's Avatar
look at these 12 led system, I use them & are excellent
http://store.ijdmtoy.com/Luxer1-12-L...anel_sku53.htm
Old Aug 16, 2011 | 08:14 PM
theewz's Avatar
LED | Autolismo
sorry to reopen this but i'm looking for led's in my dome lights as two just went in my 08 outie. Are they direct replacement?
was it the first one under here:
Festoon Bulbs | Autolismo
thanks
Old Aug 20, 2011 | 09:46 AM
theewz's Avatar
Does anyone know if any 31 mm festoon led will work?
Old Jan 9, 2012 | 02:46 PM
bedmoshe's Avatar
Dear outie friends
Yesterday i replaced my 2008 outie dome lights to white leds and ive got a problem:
the leds are working graet when the doors r open,but when i closed the doors and after a while the leds r fading out and iwant to open the lights with the dome light switch to on-the lights from the leds r very weak.
another try to open the doors they lights bright and ok.
i change last week the car batterry to a new one.
what can cause this problem???
tnx a lot
Old Jan 10, 2012 | 11:04 AM
jechenrode's Avatar
I used these in my 2007 Outlander. They work great.
3022-xHP4 High Power LED Festoon Bulb Specifications
