Drilled amd Slotted
Old Aug 4, 2004 | 12:18 PM
outlancer's Avatar
Default Drilled amd Slotted
I was cruising around on ebay when i found some drilled and slotted front brakes. I was wondering if anyone knew anything about these brakes and if they are actually worth the $140. Any info would help
Old Aug 4, 2004 | 01:54 PM
wildwest's Avatar
Default RE: Drilled amd Slotted
what are you wanting to know? brand wise or just overall performance?
Old Aug 4, 2004 | 02:03 PM
outlancer's Avatar
i want to know is it really worth it on an outlander being the performance isnt really causing a threat to its stopping ability, is it really worth the money, and would it just be better if i were to put some high performance brake pads
Old Aug 4, 2004 | 02:10 PM
wildwest's Avatar
they are great for disapating heat. if you do alot of hard braking or ever notice brake fade then sure... but for general low heat stopping. Better brake pads. Green or red stuff pads are good. Green is for mild perform, red is a little more.
Old Aug 4, 2004 | 07:08 PM
JMC's Avatar
JMC
The stock brakes and rotors suck on the Outlander.....I think you'll be really happy if you change everything over.
Cross drilled and slotted are probably the best for the Outlander.
Old Aug 6, 2004 | 07:22 PM
Punisher's Avatar
do the fronts wear out faster than the rears (brake pads)
Old Aug 6, 2004 | 07:27 PM
outlancer's Avatar
yes, on any car regardless of what type and make or what anybody else tells you the front will always go out before the back. that is why when you get harsh on the brakes the front end dips down and the rear end doesnt squat. the only way the rear would wear out faster is if you use you e-brake alot to get your car to drift
Old Aug 9, 2004 | 06:07 PM
JMC's Avatar
JMC
The back brakes are Drums so they will last longer no matter what.
r1concepts
Apr 10, 2007 07:10 PM
ray@ipp
Aug 1, 2006 06:45 PM
r1concepts
Dec 1, 2004 08:41 PM
r1concepts
Nov 30, 2004 05:57 PM
jdmsoarer
Jul 6, 2004 07:53 PM
