DVD in motion patch for NR261EM
Old Sep 12, 2012 | 09:21 AM
  #151
Streetfighter's Avatar
Hallo Otaku
I have a Peugeot 4007 with MMCS - 261EM PUG 1.10 005004.
When is on the Side the Download available and fitts that to my Car ?
Do you need more Infos to my MMCS ?
Best Regards - Robert
Old Sep 12, 2012 | 10:43 AM
  #152
siddharta_74's Avatar
Originally Posted by Otaku
I've been looking through the bootloader and kernel code - there appears to be nothing majorly different between yours and any of the other melco units ( other than the branding ).. Will examine further tomorrow..
Thanks
Old Sep 13, 2012 | 03:51 PM
  #153
Unlock your harddrive and replace the loading.kwi with the one you uploaded.
You downloaded the correct version yes ?
I finally succeded in replacing the hacked .kwi file with my original one but
the problem is still appearing......Is there a way to reset my MMCS so that
it can newly load the correct .kwi file?
Thanks
Franco
Old Sep 14, 2012 | 03:00 AM
  #154
WiValdiBB's Avatar
Thanks
Franco
You should disconnect power supply eg. acu (battery) connector, wait tehn few minutes, connect again, power on MMCS, report us.
It should initiate instaling your orginal loading.kwi
Old Sep 15, 2012 | 05:20 AM
  #155
ArmenskiaPop's Avatar
I have the same problem after trying to renew loadin.kwi
I restored from disk image, which was done in advance. The problem remains, only Peugeot logo and black screen. also unplugging the battery but no effect.
Old Sep 17, 2012 | 12:05 AM
  #156
WiValdiBB's Avatar
You have to unplug battery for any minutes, some elco caps insid MMCS must be well discharged, then instalation process of system from loading.kwi will start again. I know that situation, when loading.kwi file is wrong (wrong version, or crack), but replacing original loading.kwi on MMCS partition and coldboot with acu can fix MMCS with black logo screen and loop restarted system
Old Sep 18, 2012 | 09:19 AM
  #157
Otaku's Avatar
You hve to unplug battery for any minutes, some elco caps insid MMCS must be well discharged, then instalation process of system from loading.kwi will start again. I know that situation, when loading.kwi file is wrong (wrong version, or crack), but replacing original loading.kwi on MMCS partition and coldboot with acu can fix MMCS with black logo screen and loop restarted system
I have no idea why this is happening - I have been back over the code looking for any additional security checking on image signatures or checksums, and there simply isn't any.
Does anyone out there have an _original_ update disk for a peugeot?
Old Sep 20, 2012 | 05:25 AM
  #158
Zrieschling's Avatar
i have a brand new (orginal) PUG loading.kwi from 2012. you can try this one...
BLD.NR-261EMPUG 1.10 00.60.01
http://www.filefactory.com/file/61fz.../n/LOADING_rar
Old Sep 21, 2012 | 12:00 AM
  #159
WiValdiBB's Avatar
I think a good idea is to create database with all kinds original loadings, something like OTAKU did it with NavHack!
Old Sep 21, 2012 | 04:57 AM
  #160
Otaku's Avatar
Yeah - I'm in the process of adding the originals to the database for navhack..
