DVD in motion patch for NR261EM
Hi, download patch from www.deltainfo.ro software package NR261-EM version E DVD in motion allowed. Follow instruction exactly as discribed by Zox in page 6 of this thread. Try using a different software for burning the ISO file Roxio & Nero both work fine. If it doesn't work is probably due to APPLICATION 00.31.10 for it works for my APPL. 00.31.06.
In this case you have to wait for Otaku and his new general patch. Hope it works.
ORIGINAL: Zox
Updating procedure
1. Extract files from archive.
2. Burn the ISO file on a blank, fresh CD (in NERO, Menu -> Recorder -> Burn Image)
3. Start the engine and insert the burned CD into MMCS' unit
4. Wait for it to check the disk and to start the upgrade procedure. It may take up to a minute do make the checks.
5. Wait for the update procedure to finish. This will take 3 to 5 minutes. At the end the unit will reboot.
6. After start, you will be prompted AGAIN to update. Choose NO, the unit is already updated.
7. Remove the CD.
8. Drive carefully while enjoying your DVD movie
Updating procedure
7. Remove the CD.
Hello Outie lovers. Just got a brand new 2.2DiD with MMCS. First thing I tried is to apply Otaku's patch. I downloaded the MMCS-E-DVD.rar from DeltaInfo, using the link:Outlander Update CD, NR261-EM, Software version Version E, DVD in motion allowed. Used Nero 6.6 to burn the extracted iso image to CD (in Nero: Recorder-Burn Image), using 'TrackAtOnce' and 'Finalize CD'.
Went to my Outtie, started the engine and flipped the MMCS open. Inserted the CD and YES! it said indeed "Checking ..". After about 10 seconds the "Checking Disc" indication disappeared and nothing else happened.
Did I do something wrong?
Or is the image not suitable for my MMCS version?
The setting screen on my MMCS shows:
SW version: H
MAP version:2007-A
CDDB version:1019-0000
The Version Information behind the SET-NAVI key combination shows:
Loader:BLD-NR-261EM 1.09
Application:00.40.11
Navi Subprocessor:00.31.00 090004
Audio Subprocessor:00.34.02 003402
Map Data:M140
Monitor:00.27.00
Can Box:000120
Can anybody help me?
HNK.
Sorry for the sober layout of my profile. I need some time toupdate it.
Once the weather improves, I get some photo's to pimp my profile.
SW version: H
MAP version:2007-A
Map Data:M140
Monitor:00.27.00
Can Box:000120
HNK.
ORIGINAL: HNK
Workable link: http://www.deltainfo.ro/manuals/mitsu/outlander/
ORIGINAL: HNK
MAP version:2007-A
MAP version:2007-A
ORIGINAL: HNK
SW version: H
MAP version:2007-A
Map Data:M140
Monitor:00.27.00
Can Box:000120
HNK.
SW version: H
MAP version:2007-A
Map Data:M140
Monitor:00.27.00
Can Box:000120
HNK.
ORIGINAL: Khepri77
J' have the same thing! [/align]Is Otaku's work on a version which will take into account the 00.40.11? [/align]Please Otaku answers us.[/align]Thanks.[/align]Regards.[/align]
Yes, it should work on any future version.
If there is an incompatibility , there will be an update release ( given my understanding of the system ) within 2 days .
My problem currently is : I cannot release it until I have tested the protection system fully - this is purely a pre-emptive measure..
I want to check out any possible incompatibilities.
This requires playtime with an actual unit...
Which is apparently a problem in N.Ireland.
Again - if anyone knows someone in N.I. with an MMCS ( or a merc with the 204 unit ) , then ping me..
Until then, I'm afraid its a waiting game ..
atb.
O.
tdford, Otaku, thanks for your explanations.
So I have to spent some time in NI (not the worse of things, I think), for giving Otaku a chance to play around with my MMCS. But since I then have to leave my lovely dog behind, I don't think a trip to NI will happen in the next coming years.
Otaku has right: for the time beeing it's a waiting game. :-((
In the meantime Ihave nothing else left thengo for the lessattractive solution thatMadMax has posted on the German forum: http://www.outlander-forum.de/sogeht...-II-mmcs_1.php.
Otaku, if you ever plan a trip to Holland, you're welcome to use my MMCS for your efforts to help us all with proper solutionsfor theDVD-in-motion.
ORIGINAL: tdford
I know your MMCS is from the EU, but nice that your map version is 2007. US are still either 2005 or 2006. We are waiting for 2008 to be available, hopefully March.
