ETACS options customization
Old Jun 23, 2014 | 01:12 AM
  #1111
Jura's Avatar
Hi
I tried to remove the passenger airbag light problem using diagbox.
I can not do, can someone managed to do in the ASX?
I have diagbox V 7.40
Old Jun 23, 2014 | 04:31 AM
  #1112
Tatsfield's Avatar
Originally Posted by Vadimus
BT module is being referenced as HFM.
Of course! Hands Free Module!!! Many thanks.
Old Jun 24, 2014 | 07:50 AM
  #1113
goldfish2012's Avatar
Originally Posted by Jura
Hi
Hi,
Do you mean you want to read the error code and clear the fault? The diagbox should be able to do that unless the fault is permanent.
Old Jun 25, 2014 | 01:09 AM
  #1114
Jura's Avatar
Errors reads me set the car as a Peugeot but I can not remove this error.
Maybe even try to set for Citroen.
I changed radio and was an error but it is not a permanent problem because previously removed the Mitsubishi on it and it was OK. When you turn on the ignition and leave the panel with LED error later such problems.
Soon again I will again change the radio to the new, and probably will again this error. I would like to know if someone was able to remove it, and under what settings - Mitsubishi ASX 1.6 5MT.
Old Jun 25, 2014 | 09:25 AM
  #1115
Guyfromhe's Avatar
I don't know how you can clear the error once you get it other than at the dealer.. I have heard people not having success clearing air bag errors sometimes...
Make sure you didn't leave anything disconnected and next time you do work on your radio disconnect the battery until the work is complete to avoid any errors.
Old Jun 30, 2014 | 08:44 AM
  #1116
Vadimus's Avatar
On RVR/ASX/Outlander Sport it is enough to turn ignition once while having radio faceplate disconnected - and non-disappearing airbag light will stay until erased.
On Outlander however, it is enough to reconnect faceplate and airbag light is gone.
Old Jul 1, 2014 | 02:36 AM
  #1117
Jura's Avatar
exactly
Unfortunately, somehow we have to live with that "deficiency" Mitsubishi and delete it when the need arises
The problem now lies on how to remove it using this cable (lexia)
Old Jul 10, 2014 | 01:50 AM
  #1118
Abdulrhman Khaled Al-magrabi's Avatar
dear all,
can it remove the speed limiter on 2010 GCC Outlander 3.0 or not?
it goes till 205KPH then it slows down
thanks
Old Jul 20, 2014 | 09:27 AM
  #1119
Vadimus's Avatar
Originally Posted by Abdulrhman Khaled Al-magrabi
dear all,
thanks
Yes, most likely. There's a speed limit option in your engine ECU settings.
Old Jul 21, 2014 | 05:56 AM
  #1120
Thumbs up
dear Vadimus,
all I can say thank you so so so much.
you just made my day bro and I appreciate you for showing me this.
I have two question for you
1- what do I need to remove it? ig.laptop with windows 7 or xp, which program should I use diagbox or what and which device Lexia-3 there are many versions should I buy.
2- is it easy to do or should I back up something before I start playing with it?
best regards,
