ETACS options customization
Just changed to winter wheels.
Used Lexia to shut the TPMS. Lexia kept the lock at 20km/h no redoing needed.
Had to redo what I changed using PP2000 i.e. unlock on park.
Had to redo what I changed using the FAST key i.e. Unlock all door on touching the driver's door handle and toot the horn on first lock button press.
I initializes the lock when the key is detected outside the window but it does not work.
I will report how the disabling of TPMS is working a little later when I put some millage on the modification.
Can you give us some details about diagbox? Does it have all the settings available in PP+Lexia or do you really need all 3 to change all the settings?
Does diagbox make some of those unknown values "known" so you can change more things safely?
EDIT: Just installed 6.01 and it doesn't detect the car at all. Apparently you have to de-solder a chip and program another one. You also have to downgrade the main flash which it updates when you run the program.
No need for resoldering, just downgrade the cable's firmware to 4.2.4 using PSA Checker tool.
I tried that, it just reprograms each time you open open the software. Tried it twice...do you need to program it while diagbox is running?
And yes, you can reprogram anytime, with Diagbox running too.
Do you have the Lexia tool? I plan to go to Laredo this month or in december. . .
