exhaust
Old Jul 3, 2004 | 11:55 AM
outlancer's Avatar
Default exhaust
i already have my exhaust done but does anyone else running some type of muffler cause i want to know how it sounds. mine is real deep and i dont have the last muffler on anymore i just took it of and ran more pipe to the back
Old Jul 12, 2004 | 10:35 AM
urbagurba's Avatar
Default RE: exhaust
once again once you take stock exhaust off- it voids warranty.. best bet is to go to an exhaust shop and have them put on a cat back properly. you can get alot of different sounds depending if you want resonating, or non resonating... make sure you have computer reprogrammed, or any horsepower gains will be lost
Old Dec 11, 2004 | 09:44 PM
wicked_outlander's Avatar
Default RE: exhaust
try ol' school magnaflow muffler, then remove resonator pipe...replace it w/ 3' pipe...sounds agressive!!!
Old Dec 16, 2004 | 06:52 PM
JMC's Avatar
JMC
Default RE: exhaust
Battlez Exhaust
RS Exh Tip Size (mm): 101.6
Center Pipe Size (mm): 50.8
Noise db: 90
It's sweet!
Old Dec 27, 2004 | 04:37 PM
Default RE: exhaust
total cost??
Old Dec 28, 2004 | 02:20 PM
JMC's Avatar
JMC
Default RE: exhaust
The Exhaust was around $200 or so.....I got a good deal through a shop.
Old Jan 10, 2005 | 02:11 PM
rocco0222's Avatar
Default RE: exhaust
Most cases the bigger the pipe the deeper the sound, but i wouldnt go over 2.5inch on a 4cly, you will loose too much backpressure, and rob hp.
Old Jan 11, 2005 | 06:23 PM
JMC's Avatar
JMC
Default RE: exhaust
I think you could get away with 3.0 inch.............
Old Jan 19, 2005 | 01:21 PM
rocco0222's Avatar
Default RE: exhaust
no you couldnt, you could physically, but it would be pointless, you would loose a ton of HP im telling you not enough backpressure.
Old Feb 17, 2005 | 03:45 AM
Default RE: exhaust
i, guess 3.0 will add up some power, but the weight will kill the ratio.
q7suited
Aug 12, 2008 05:48 PM
anko_kun
Mar 6, 2008 08:54 AM
