Fault code p1351
Old Jul 11, 2016 | 10:36 AM
raptornexus's Avatar
Default Fault code p1351
Hi my Outlander 2007 2.2 Diesel has recently been slightly misfiring when picking up the drive from coasting,most noticeable when in fourth gear.It does it randomly but is very annoying.Ive done a fault code read and its got 2 codes P1351 and P1351P any ideas guys ? Thanks in advance.
Old Jul 12, 2016 | 01:53 AM
This site is ****.....never once has anyone answered a question ive posted !!!!!
Old Jul 12, 2016 | 02:10 AM
SERPENTOR's Avatar
Old Jul 12, 2016 | 12:10 PM
ccernst's Avatar
Your ideas of how a small forum answers questions regarding an even smaller subset of vehicles with a particular engine is $hit. You didn't even give it 24hrs. Take a long walk on a short pier.
Old Jul 13, 2016 | 09:41 PM
gggplaya's Avatar
Because you have a diesel, it's most likely a bad injector from that code.
Old Jul 14, 2016 | 12:01 PM
After you !!!!!
Old Aug 14, 2019 | 07:20 AM
WiValdiBB's Avatar
Glow plug error, test them with multimeter on glow plug relay socket
Can be also relay problem
Old Oct 27, 2019 | 09:28 AM
Carbon8ed's Avatar
Can confirm glow plug error, if it's the PSA 2.2 HDi, number 3 is difficult to get too.
HTH
Old Oct 28, 2019 | 03:34 AM
WiValdiBB's Avatar
HTH
Its difficult but possible,
I changed nr 3 too, without disconecting EGR
The most difficult is to take rubber cap off
I made a tool from a piece of pipe
I took steel pipe which I found inside plywood cable drum, cuted a bit and bended ends from two sides to create kind of nails
Then i put that and shifted from a flank of glow plug cap, then I silmply disconnected cap by pulling pipe tool, the next problem were to take thjat tool out from disconnected glow plug cap, but successfully done
Before that i removed few screws on right side of engine block, covered plug nr 4 to make some more space
When glow plug cap were off, I easily replaced glow plug, and pushed cap into glow plug by finger press, its just clicked,
It took me half hour
If needed I can make picture of "tool":
Greets
Old Mar 8, 2023 | 06:18 AM
Whisckey's Avatar
Default P1351
hI did you manage to resolve the issue ? , I have the same problem ?
