Firestone air support
Old Apr 23, 2014 | 04:08 PM
boogunoogun's Avatar
cool. thanks!
Old Apr 26, 2014 | 04:47 PM
sanducrl's Avatar
Default 2007 Outlander Air Helper MOT Failure
Hi All,
I've got a 2007 Outlander 2.0 did and I want to install Firestone air helpers but, does anyone know if air helper is subject of MOT failure in UK?
Thanks
Old May 11, 2014 | 01:23 AM
mdbullet223's Avatar
Originally Posted by The Grocer
Just fitted Firestone air support sleeves to my 2007 Outlander. Absolutely ideal for when the rear is loaded and I am towing my caravan.
The fitting can be done without dropping the suspension arms etc., but is fiddly and took me about 5 hours in total.
Photo at:-
http://www.flickr.com/photos/the_grocer/8467636663/
What size trailore will you be towing? keep us informed with hitch and wireing harness you used! Dave
Old May 11, 2014 | 03:12 AM
The Grocer's Avatar
I tow either my single axle caravan or twin axle trailer. Whilst the caravan, being the heaviest at around 1600kg laden weight, the Mitsi is also loaded rather heavily in the rear. Despite being well within its abilities I found the air assist excellent for keeping the configuration level.
The Mitsi tow gear was factory fitted and the extra caravan wiring installed professionally...
Old Jun 6, 2014 | 02:58 AM
bolts_fan's Avatar
Originally Posted by boogunoogun
Then you need to buy a pump and controller correct? I wonder if someone makes a rubber spring booster for our car
Here, check this out.
2005-2013 Mitsubishi Outlander - Coil SumoSprings [Rear] - CSS-1125 | $114.30
Old Feb 2, 2015 | 07:29 AM
billb1's Avatar
Do these air spring kits last long?Some say they get puncture holes in them.
Old Feb 3, 2015 | 05:49 AM
2001Mitch3.5XS's Avatar
You don't have to pressurize all the time, After towing you need to let the pressure down or you will be bouncing all over the place lol.
I had my air bags in for 4 years now and as long as you use the heat shields right you won't have any problems with them.
Old Feb 5, 2015 | 02:52 PM
billb1's Avatar
2001Mitch3.5XS,what kind of car and what type of airbag do you have?If it's airlift,what is the part number for an outlander 2012
billb1
Mar 7, 2017 10:04 AM
billb1
Feb 21, 2015 06:42 AM
UltraSmooth
May 30, 2012 01:34 PM
Jay Envy
Jun 28, 2007 03:21 PM
