fluid extractor for ATF change
does anyone know if a fluid extractor via the ATF dipstick hole is going to be able to do a somewhat proper fluid change without making a mess. Equavalent amount as disconnecting the transmission line etc.
The good thing about this, is that you can easily measure and put the same amount of fluid back in http://www.amazon.com/Mityvac-7400-L.../dp/B000JFJM14 |
Transmission fluid extraction
I’ve done this twice on our Outlander Sport it will only draw off a gallon of fluid at a time though.just do it more often |
Originally Posted by Hodado
(Post 324467)
I’ve done this twice on our Outlander Sport it will only draw off a gallon of fluid at a time though.just do it more often You'd be better off just draining the pan if you dont want to pull the return line. |
