fluid extractor for ATF change
Old Jul 25, 2012 | 11:28 AM
OutlanderGT's Avatar
Default fluid extractor for ATF change
does anyone know if a fluid extractor via the ATF dipstick hole is going to be able to do a somewhat proper fluid change without making a mess. Equavalent amount as disconnecting the transmission line etc.
The good thing about this, is that you can easily measure and put the same amount of fluid back in
http://www.amazon.com/Mityvac-7400-L.../dp/B000JFJM14
Old Jul 12, 2018 | 04:46 PM
Hodado's Avatar
Default Transmission fluid extraction
I’ve done this twice on our Outlander Sport
it will only draw off a gallon of fluid at a time though.just do it more often
Old Jul 13, 2018 | 09:28 PM
ccernst's Avatar
sport has a cvt, totally different animal.
You'd be better off just draining the pan if you dont want to pull the return line.
newoutlanderfan
May 27, 2013 10:47 AM
2k1monterosport
Feb 16, 2011 10:47 PM
Greg8325
Nov 17, 2008 08:15 PM
chrisacain
May 29, 2005 10:31 PM
