Fuel Eco. - 60L tank gets you how far?
Old Jan 12, 2011 | 04:42 PM
bigrroberto's Avatar
Originally Posted by nesser
Right now in the winter I get about 400km combined highway/city driving in a Canadian 2009 V6 XLS per tank using REGULAR gas running on my winter tires. I fill up just after the first warning where there is ~10L of fuel left in the tank so calculate using 50L instead of the 60L tank size.
There is more time warming up the car while I'm brushing it off. Can't just jump in and go like in the summer. Also it takes longer for the vehicle to warm up into it's normal operating temperature so it burns more fuel trying to get there faster (higher RPM's when you start cold). Therefore many shorter trips will give you bad mileage since you're running in the warm up mode more often.
The 2010's suggest premium fuel. Not sure if that is just horsepower boost or fuel economy too.
Dude you should bee running premium. The manual doesnt just 'suggest' premium, its required. The reason the 2010 has more hp than the 2009 is because they actually tuned the car differently. With the new tune you require premium fuel or you risk the chance of engine knock.
Premium fuel on its on isnt going to net you hp or fuel economy, the vehicle has to be tuned for it to be effective. For example putting premium in your parents 95 astro van isnt going to make a lick of difference as the engine isnt set-up to utilize the extra octane. However if you were to put regular in a new evo, the thing would knock and go boom.
This is why its important to use the type of fuel the manufacturer requires. The difference in price ($6 on a full tank) isnt going to kill anyone that can afford to purchase this vehicle.
Edit: I get about 400km to a tank all city driving. and when i took it out to the mountains I got about 600km to the tank on purely highway driving. That was also through the mountains and at the time was still technically in the `break-in` period as I only had about 5000km on it. I would think a highway trip through the prairies, at the speed limit, should net around that 600-650km a tank range.
Old Jan 12, 2011 | 08:48 PM
ivanz's Avatar
Originally Posted by Colt-Speed Ca
Wow…220 km to a tank…that must’ve been uphill both ways in 4wd lock with the A/C on and windows down!
Actually, its downhill in the morning and uphill in the afternoon. Regular 4WD auto if its raining or 2WD if not. Very light on the throttle and no A/C.
Most cars I've driven get around the same on that trip, so the Outlander isn't any worse in terms of fuel consumption.
Old Jan 13, 2011 | 01:43 PM
UltraSmooth's Avatar
I looked at my manual for my 2010 XLS it does not state that premium is required, only recommended. It says 87 or higher is required, while premium is recommended for best performance.
I'm only on my second tank (first tank was dealer filled) and used regular this tank, have noticed no difference so far.
Old Jan 13, 2011 | 02:26 PM
bender031177's Avatar
I got 522 km (all high way) to a tank with my 2009 XLS (3.0L V6) which was 10.6 l/100km. My average is about 450 km per tank or 11.41 l/100km. I cruise at 110-120 kph. This is based on records I have kept over the past six months. Mine has 37,000km on it.
I get 400 km when I am towing my camping trailer (2,000 lbs) at 100 kph.
As for the premium fuel debate, it is "recomended" not "required". The compression went from 9.5:1 to 10.5:1 which is the main reason for the premium recomend and the torgue and horse power increase. You should see more of a differance after a few years when the carbon deposits in the engine limit it's ability to retard the timing. Thats what happened to my Grandfathers '05 Galant LS V6 which also had premium recomended.
Old Jan 13, 2011 | 08:15 PM
Of course you wont notice a difference. Its not like adding nos lol. Doesnt mean that it isnt making a difference. For the small amount of price difference I'd highly recommend it.
This is why...
dubik
Jul 17, 2017 06:46 PM
sublevel4
Nov 3, 2009 08:49 PM
spyder4g63t
May 21, 2007 09:48 PM
93eclipsegsx
1st Generation
37
Mar 9, 2007 01:17 AM
newEclipse
4th Generation
May 6, 2005 12:47 PM
