Fuse Box ? Fuses Small Size
Old Jan 25, 2016 | 04:36 AM
AdamCrossland's Avatar
Default Fuse Box ? Fuses Small Size
I I'm trying to get all my accesory sockets working on my 57 Plate Outlander Elegance as the cigarette and other charge ports don't work but I think I have found the fuse box left hand passenger side when I take the glove box out but the Fuses are a much smaller size than normal ones am I in the right place ?
Old Jan 25, 2016 | 09:06 AM
gggplaya's Avatar
Yes, most newer cars don't use full size fuses anymore. Instead they use mini fuses which are just as good, but in a smaller package. This is because cars are continually adding new electronic feature, more cigarette lighter sockets, more gadgets, more things like ABS, Lane Departure warning, Radar cruise, more switches, more buttons etc........ All means more fuses, so they had to miniaturize to allow for more fuses in the fuse box.
Just go to the auto parts store and buy the smaller fuses.
get something like this, which has a fuse tester and puller. It has a green light to tell you if a fuse is good or bad.
Robot Check Robot Check
Old Jan 25, 2016 | 10:56 AM
Thx a lot mate all done got all the accesory sockets working bar one that's in the compartment between the driver and passenger seats looks like it may need rewiring back in ?
Old Jan 25, 2016 | 11:05 AM
gggplaya's Avatar
On my outlander, the one between the driver and passenger seat is turned on all the time, regardless of the key switch position. I try not to use that because i'm afraid if i leave a GPS or something plugged into it while i'm parked, it'll drain my battery.
Did you also check to see if there were any fuses in the engine bay?? There's usually a fuse box just behind the battery. But i can't remember for our cars.
Old Jan 25, 2016 | 11:12 AM
That's interesting about the one between driver and passenger seats if I get it working I will have to be careful haha
Didn't check the engine bay will have a look in the morning mate ta
Old Jan 25, 2016 | 12:26 PM
Guyfromhe's Avatar
I have a phone charger in the front accessory socket (under the radio) on my 2010 and it turns off with the car... I didn't check the centre console one yet though.
Old Jan 25, 2016 | 12:27 PM
gggplaya's Avatar
Yea, the front center console and the rear cargo area sockets both turn off with the ignition. But the center console on mine doesn't, it's on all the time.
Old Dec 5, 2016 | 11:20 AM
n0c7's Avatar
Has anyone found a solution to have the center console one on ignition?
Old Dec 5, 2016 | 10:09 PM
gulleyman's Avatar
Default Thank you!
Now I have power adapters again
Old Oct 29, 2017 | 11:28 AM
Dave008's Avatar
Hi guys, I have a 09 outlander 2.4L battery drain over night, tested and draining in fuse number 7 and number 8.... 7 is the radio and I have no idea whats is the number 8. In the manual it says CONTROL UNIT RELAY.
anyone knows whats is the control unit relay and konws where is it??
peebo
Feb 8, 2009 07:56 PM
budh
May 28, 2007 10:14 AM
I Drive Naked
Apr 13, 2007 01:55 AM
Crich4
Apr 4, 2006 12:56 PM
GrayGh0st
Jan 27, 2005 10:58 AM
