Hacking the MMCS, ideas
Old Jan 8, 2009 | 08:56 AM
runestone's Avatar
Default Hacking the MMCS, ideas
Hi all, I was looking through the registry dump from Otaku where i saw this:
NR261UM.reg.txt
[HKEY_LOCAL_MACHINE\ExtModems\BluetoothDUN]
"FriendlyName"="Bluetooth_DUN"
"DeviceType"=dword:00000001
"Port"="COM4:"
[HKEY_LOCAL_MACHINE\ExtModems\BluetoothDUN\Settings]
"Tone"="
[HKEY_LOCAL_MACHINE\ExtModems\BluetoothDUN\Init]
Does this mean we could hook the MMCS up to internet through a BT cellphone? Or is the bluetooth module only used separately from the MMCS?
Is it possible to add USB peripherals somehow to the MMCS, to ie add a BT module or a DVB-T reciever ;-)
Just brainstorming...
Old Jan 8, 2009 | 05:50 PM
rcpax's Avatar
Default RE: Hacking the MMCS, ideas
The Japan version of the MMCS has the ability to accept a TV Tuner, but they must have a certain port for the tuner to go, or at least a certain pin assignment in the existing ports. The BT module looks like it's only for voice, since the only visible/detectable profile is for HF system. The Renesas chip that runs the MMCS is USB capable though, and I think if we get a diagram or application note, we would know which pins to solder the USB connector. I just don't have the guts to void my MMCS waranty right now. Dissambling the thing looks very complicated. You could easily pop a spring and wouldn't know where it goes. After 5 years maybe then I can play with it more.
hereclipse
May 13, 2005 02:57 AM
1398spdr
Oct 17, 2004 03:28 PM
wildwest
Jun 4, 2004 09:37 PM
xXEcLipse GTXx
Feb 24, 2004 01:31 AM
eclipse_rider
Oct 16, 2003 03:02 AM
