Headlamp high beam help
Hi guys.
I have a 2007 XLS (non HID) still running strong. I had to change my headlamps in 2018 and I got a pair from rockauto.com. I didn’t get the cheapest one coz I’m a believer of you get what you pay for. Anyways, my issue is that the high beams on the LH side are aimed higher than the low beams on the same side. What’s more is that the high beam on the RH side is in the same alignment as it’s low beam. I thought that the LH headlamp was defective so I had that replaced., only to get the same results. I took it to my dealer to have it aligned and they tell me there is only one way to adjust to headlights and that they get adjusted in tandem.
I wanted to find out what’s your experiences guys.
Does this look right?
Thanks for any info and/or advice.
helpmehit9s.com
Apr 8, 2006 01:49 AM
