Help finding: Keyless knob cover and base
The keyless **** base in my 2011 Outlander is broken, and I can't find the replacement part on the internet anywhere. See picture of the item I'm looking for. The closed part I could find is here: Ignition **** cover & base for Smart Start keyless systems, but it's for a Mazda and I'm not confident that it will fit since the base (part on the left) seems to be specific to the vehicle. Does anyone have any leads on this part?
Thanks!
Back of base (part that is broken) I previously tried glue with no success which is why it look gummy.
Thanks!
Wow thanks! Sure enough that's the part.
Doing more research on this I found a TSB published by Mazda (Bulletin No: 09-019/12) that references this part because it was breaking too easily. The new Mazda part number for this same item is D6Y1-76-142. I found it on eBay really cheap and just went ahead and bought it. It's shaped differently on the top (doesn't have the same curved fins) but the back is the same and fits perfectly. The cover fits also, and I'm still able to use the backup FAST key as an alternative. Here are pictures for future reference.
Mitsubishi part #4408A167
Mazda part #D6Y1-76-142
So although they look slightly different, they function exactly the same. Thanks again for your reply!
Found this interesting as well
CAP-LOCK CYLINDER
Make: Chrysler | Part#: 4408A167
CAP-LOCK CYLINDER
Make: Dodge | Part#: 4408A167
CAP-LOCK CYLINDER
Make: Jeep | Part#: 4408A167
Also referenced in this post
https://mitsubishiforum.com/forum/mi...ey-****-33260/
CAP-LOCK CYLINDER
CAP-LOCK CYLINDER
CAP-LOCK CYLINDER
cutepuppy671
Oct 26, 2014 07:57 AM
dfreem01
Feb 21, 2014 02:24 PM
