Help with hard starting condition (2015 Outlander SE)
Vehicle: 2015 Mitsubishi Outlander SE, Engine: 3.0L V6, Mileage: ~120,000 km
Issue:
- Long crank and stumble on start after the vehicle has been sitting (crank crank crank crank crank crank stumble stumble stumble start)
- It's been about a year and now seems to be getting worse. Before it would occur intermittently, now every morning it's happening.
Symptoms:
- Engine cranks strongly (normal crank speed).
- Crank duration can be 6–10 seconds before firing. Smells a tad like fuel after.
- When it catches (95% of the time), it stumbles/rough idles for a few seconds.
- After a few seconds, idle smooths out completely.
- Vehicle drives perfectly once running.
- Acceleration is normal.
No hesitation under load.
Warm restarts (after 5–10 minutes) are smooth and immediate.
Turning ignition ON/OFF multiple times before cranking (to build fuel pressure) doesn't seem to help.
Occasionally:
- Instance of crank/no-start on first attempt.
- On second attempt, pressing accelerator (clear flood mode) allows it to start.
- Using Scan Tool - No engine codes present.
Sit time:
10 minutes → starts normally.
1–2 hours → may long crank and stumble.
Overnight → most likely to long crank and stumble.
Behavior inconsistent day to day.
Work done to try and resolve:
- Battery tests good (1 year old).
- Alternator tests good.
- Timing belt replaced.
- Spark plugs replaced.
- Throttle body previously cleaned (seemed to help a bit about a year ago).
- Software update applied.
- Crankshaft position sensor replaced (OEM Mitsubishi part).
- Issue persists after crank sensor replacement.
What to check next? Dealership suggests it could be injector leak-down while sitting?
At a loss and want to figure it out, I really like my Outlander and want to fix it but don't want to continue chasing randomly.
Any experience or assistance would be greatly appreciated. Thanks Mitsu community!
Issue:
Symptoms:
Occasionally:
Sit time:
Issue:
Symptoms:
Occasionally:
Sit time:
Issue:
Symptoms:
Occasionally:
Sit time:
Thanks for the suggestion. I have tried clear-flood (pedal to the floor while cranking), and when it is struggling to start/stumbling it does get the engine to catch/start.
I've been also trying to put key on for 10 seconds, key off, and repeat several times and it seems to be helping. If I leave the car for longer than 2-3 hours and try to start it - it will long crank and stumble again.
Any ideas what to test next?
jcb72
Dec 18, 2011 03:17 PM
