cranking 130-165rpm ignition problem?
Old Jan 24, 2013 | 09:11 PM
Jeremy Ivy's Avatar
Default cranking 130-165rpm ignition problem?
Its a dodge stratus with the 3.0. Turn key on and crank it and fuel pump never kicks on. Pulling plugs they are wet and do spark nice bright n blue. No codes timing belts good. And fuel pressure is good.
Won't even start with starting fluid.
My obd2 shows when cranking it turns 130-165 rpms.
Unplugging the crank position sensor my pump does the purge and does a purge when I plug it back in.
I'm leaning towards the crank sensor but I haven't found what a engine should be cranking at. I thought more like 300.
Good battery n starter. Motor is cranking good just reads the 130-165rpm
So is my crank sensor reading bad?
allallyouyou
Feb 12, 2012 11:13 PM
Scubba.steve
Oct 11, 2008 01:11 PM
jamesdthomas2
Jul 1, 2007 02:06 PM
gs_dirtdog
Jan 11, 2007 10:45 PM
irdefector
Jul 6, 2006 07:23 PM
