Help to locate video-in , on rear of NAV unit
Hi All, I bought a 2007 Outlander sun and sound,XLS Lux,and had no Nav unit. i told the dealer ill buy the car only with NAV unit. They installed the NAV unit,and when i got home i noticed the back of the rear concole didn't have VIDEO-IN, only AUDIO white and red.I thentouched the SET and NAV botton on the Nav unitto go tothe Service screen, and then touched the Network/Connect tab and saw that Video in was active (ok). so can someone show me a pic that shows the VIDEOIN/Aux so i can add a Video RCA jack. Im adding a rear cam and i know where that gets pluged in,and hope its not the same place as the Video Aux IN...Thanks.
[IMG]local://upfiles/15391/F75E3967EA2147FCA9342703F376FB51.jpg[/IMG] |
RE: Help to locate video-in , on rear of NAV unit
Well, I have added it to my unit..
You need to pop out that unit holding the Red/Wht audio jacks Then hit the radio shack and get the RCA type that can be screwed onto the plactic after you drill the hole.. Solder the RCA to the PCB like the others then find some connectors with pins that are long enuf and can be bent like the others on the PCB. I will find the info for taking apart, I did enuf so I could push the aux block out, and unplug I kinda wish I had a camera and took pixs. Maybe I will pop it out and show the end results It does work BTW Old |
whats a PCB, and thanks for the info.....
Printed circuit board.. The other 2 RCA are wired to it, on the other end the pins of the plug stick out. The are bent at 90 degrees just above the circuit board
Old |
Hey ,thanks again.I did it with some suff i found in the junk drawer.
ill put pics in once i figure out how..:eek: |
here is a RCA jack i found on a old PC bord i had
[IMG]local://upfiles/15391/AFFF4D245DC44FD8B562E53D782BC6AF.jpg[/IMG] i then use a dremer toll to cut out the hole on the cap |
after drilling holes, i cut two pieces off a paper clip to make the two connectors for the video.
i solder them, and the video jack, put everything togethr, and wala ! |
oh and also you may want to file both sides of the pins to make them flat.
[IMG]local://upfiles/15391/DBC0326C0C854D33B886FE89FF96F4EA.jpg[/IMG] |
Yup, u had the good stuff, the junk drawer of mine , well, moved from Chicago to near Salt Lake, all the pack rat stuff had to go except a box the movers picked up that was garbadge.. And that was my source (old VCR parts)
I knew you coluld doit.. OLD. BTW, works great hey! |
