Help to locate video-in , on rear of NAV unit
Old Dec 9, 2007 | 10:36 AM
rayp35's Avatar
Default Help to locate video-in , on rear of NAV unit
Hi All, I bought a 2007 Outlander sun and sound,XLS Lux,and had no Nav unit. i told the dealer ill buy the car only with NAV unit. They installed the NAV unit,and when i got home i noticed the back of the rear concole didn't have VIDEO-IN, only AUDIO white and red.I thentouched the SET and NAV botton on the Nav unitto go tothe Service screen, and then touched the Network/Connect tab and saw that Video in was active (ok). so can someone show me a pic that shows the VIDEOIN/Aux so i can add a Video RCA jack. Im adding a rear cam and i know where that gets pluged in,and hope its not the same place as the Video Aux IN...Thanks.
[IMG]local://upfiles/15391/F75E3967EA2147FCA9342703F376FB51.jpg[/IMG]
Old Dec 9, 2007 | 10:44 AM
oldpapa1949's Avatar
Default RE: Help to locate video-in , on rear of NAV unit
Well, I have added it to my unit..
You need to pop out that unit holding the Red/Wht audio jacks
Then hit the radio shack and get the RCA type that can be screwed onto the plactic after you drill the hole..
Solder the RCA to the PCB like the others then find some connectors with pins that are long enuf and can be bent like the others on the PCB.
I will find the info for taking apart, I did enuf so I could push the aux block out, and unplug
I kinda wish I had a camera and took pixs.
Maybe I will pop it out and show the end results
It does work BTW
Old
Old Dec 9, 2007 | 10:55 AM
rayp35's Avatar
whats a PCB, and thanks for the info.....
Old Dec 9, 2007 | 02:29 PM
Printed circuit board.. The other 2 RCA are wired to it, on the other end the pins of the plug stick out. The are bent at 90 degrees just above the circuit board
Old
Old Dec 10, 2007 | 05:23 AM
rayp35's Avatar
Hey ,thanks again.I did it with some suff i found in the junk drawer.
ill put pics in once i figure out how..
Old Dec 10, 2007 | 05:28 AM
rayp35's Avatar
here is a RCA jack i found on a old PC bord i had
[IMG]local://upfiles/15391/AFFF4D245DC44FD8B562E53D782BC6AF.jpg[/IMG]
i then use a dremer toll to cut out the hole on the cap
Old Dec 10, 2007 | 05:40 AM
rayp35's Avatar
after drilling holes, i cut two pieces off a paper clip to make the two connectors for the video.
i solder them, and the video jack, put everything togethr, and wala !
Old Dec 10, 2007 | 05:47 AM
rayp35's Avatar
oh and also you may want to file both sides of the pins to make them flat.
[IMG]local://upfiles/15391/DBC0326C0C854D33B886FE89FF96F4EA.jpg[/IMG]
Old Dec 10, 2007 | 08:14 AM
Yup, u had the good stuff, the junk drawer of mine , well, moved from Chicago to near Salt Lake, all the pack rat stuff had to go except a box the movers picked up that was garbadge.. And that was my source (old VCR parts)
I knew you coluld doit..
OLD.
BTW, works great hey!
Deon
May 11, 2015 01:45 AM
navidbe
Nov 20, 2013 09:17 PM
ajoesmith
Oct 21, 2011 11:31 AM
alclot
Jan 20, 2011 10:30 PM
oldpapa1949
Nov 16, 2007 12:00 PM
