Helper springs for towing
Old Aug 25, 2009 | 01:39 PM
bobmga62's Avatar
Default Helper springs for towing
Hi..
Since the trialer hitch issue is now nine pages in length, and absolutely excellently covered ( I installed a Curt, and found a harness thanks to the help of the thread...)
anyhow, I pull approx 2,880 lbs (a HP Triumph Spitfire) to include a trailer and more than likely will need a little lift at the back end (every vehicle for the past 25 years has needed this assist..)
Has anyone had any luck with a desired installation..
I saw one on JC Whitney, which was a spring that surronded the shock absorber.. looked pretty good and inexpensive, but, may interfere with the ride at all times..
Anyone try an air lift bladder within the
coil.. if so, how did it work, and how much of an effort to install....
Last question, this is the first FWD automobile aI have towed with.. would it be more stable if I ran it in AWD??
thanks for your help...
bobmga62
Old Aug 26, 2009 | 09:28 AM
tcp's Avatar
tcp
Default From my previous posts:
you can get airbags that fit inside the rear coils of the outlander. The firestone coilrite 4106 kit should fit and has been used by someone here. The number shown by firestone is 4182.
http://www.fsip.com/riderite/rrkit/k...i=521&rrk=4182
I installed a set on my sienna in about 1.5 hours. the outlander shouldn't take longer.
http://www.fsip.com/riderite/products/crinfo.shtml
Please see thread here:
https://mitsubishiforum.com/forum/sh...ad.php?t=33304
Old Aug 27, 2009 | 03:17 PM
bobmga62's Avatar
thanks for the advice..
I have ordered the towing wiring harness from Mitsubishi, and the firestone Coil rite's from Suspension components.
When I receive and install, will give a details on installation hassles and non-hassles..
thanks for all the help, both the wiring harness and coil rites I could not find through a normal google search...
tfaas
Mar 28, 2015 02:00 AM
mistaashby12
Aug 7, 2008 05:56 AM
speedform
Apr 1, 2005 07:47 PM
1lowclipse
Sep 10, 2004 05:54 PM
Kuma
Jan 28, 2004 11:26 AM
