HID Converstion
Old Mar 26, 2009 | 04:17 AM
Sergy's Avatar
Originally Posted by klas
considering that Outlander XLS costs about twice as much in Russia, $2k for HIDs might be not bad, but then that raises an interesting question...
so top of the line Outander is 1,772,505 rubles... that's about $52k MSRP... ouch! Is average salary higher in Russia these days then in US that people can afford cars at the price? Amazing! Maybe I should consider moving back!
http://www.mitsubishi-motors.ru/comm...rice/GS45X.pdf
Not only the Outie has twice prices
All of autos on our market.
By the way I saw real prices 7 days ago in our dealer shop: Outlander V6 AT costs from 1'190'000 RUR to 1'290'000 RUR (~34'000...36'800 USD) top version.
As I wrote, US $2000 - is high price. But I can't make dicomfort to other drivers and ready to pay for it.
Old Apr 6, 2009 | 11:00 PM
jsrd's Avatar
Originally Posted by Sergy
jsrd, few questions (may be stupid, sorry):
1) How I can understand which of those parts are already installed in my car?
2) My Outie is 2.4 CVT version, does it have "pre-wiring" or not ?
3) Where I can find showed connector fot cheking pairs of HID/halogen wires ?
Thank you.
Sergy, here some details about your questions:
1) Since your Out has the halogen system headlamp, you will not find any component relative to the system HID, all must be bought separately
2) I took the diagrams from service manual relative HID system, and I was following, step by step, each line/wire to know if my has the prewiring. Basically, we must look for:
- front harness connector,
- rear harness connector,
- ECU levelling harness,
- and find the holes and supports to attach the front/rear sensors
I will upload the pics of location of these connectors
3) It is the same connector of your halogen headlamp, it's share the same connector but with different wires
in addition, HID headlamp has a fuse of greater capacity, located in the engine fuse box
Old Apr 7, 2009 | 04:41 PM
jsrd's Avatar
Sergy, to locate the following components and prewiring, search here:
1. Front sensor connector, look inside engine compartment, RH side
2. Remove lower glove box and search in lower right corner for ECU levelling spare harness
3. Remove small cubby to can see rear sensor connector; isn't necessary to remove the entire panel, is possible to see the connector through hole; in addition, to install rear harness, isn't necessary to remove the panel. This pics are reference and I took them from forum...
Old Apr 7, 2009 | 05:05 PM
Sergy's Avatar
Nice job! Thank you for useful info.
If I wont find prewiring in my Outie - that's mean I can't make to OEM HID conversion ?
Old Apr 7, 2009 | 05:17 PM
jsrd's Avatar
Sergy, you could use only HID headlamps, and not buy the sensors, harness and ECU levelling; look if your Outie has the 20 A fuses and HID wires on headlamp connector, y ONLY HID headlamps will be necessary. Remember, it's necessary to reprogram ETACS for levelling system. . .
Old Jun 24, 2009 | 04:04 AM
Sergy's Avatar
Thank you, jsrd
reaper13
Nov 5, 2007 11:16 PM
EclipseSlimRS
May 16, 2004 07:10 PM
ctbanker
Aug 31, 2003 05:44 PM
ctbanker
Jul 6, 2003 04:57 PM
minkoj0101
Jun 18, 2003 11:51 AM
