Hitch Wiring Harness
Hi
I hope someone can help, i have a 2011 Outlander and have bought the mitsubishi wiring harness but cannot find the plug in the engine bay, despite the instructions. Has anyone any photos of the location of this plug.
thanks
Paul
thanks
Paul
When I used that to get 12v to the rear of the car I found it to be tapped to the underside of the loom that goes to the light cluster.
Take the battery off (using usual precautions) and that should make it easier to see and get too.
Steve
Thanks guys found it taped to a wire under the headlight cluster, install is now complete but not what i would call easy.
For those that may be considering the install should note that i had several access issues, wires on left hand side pillar were difficult to unclip due to subwoofer, access to predrilled exit hole was restricted by seat belt assembly for rear bench, hardest of the lot was threading the cable to the outside as it is in the tightest part of the bumber. Hands are cut to pieces would definitely pay to get it done next time. Fitting the towbar was a doddle by comparison.
Paul
Paul
Paul
Paul
it does have a + sign next to it.
thats why i wasnt sure.
thanks for the info.
mmafan
Jun 17, 2009 04:54 PM
chili_g
Apr 27, 2008 08:48 PM
It goes to the Positive (+) side of the battery.
they are there for a reason
