HKS Air Filter? Lancer OEM dimensions?
Old May 29, 2008 | 05:59 PM
gluv4u2's Avatar
Default HKS Air Filter? Lancer OEM dimensions?
Hi all,
Just wanted to see if anyone knew if the OEM Air filter is the same dimensions as the Lancer OEM Air box? I want to buy a replacement air filter (like K&N, HKS or Apexi)
My main reasons for getting a better air filter is, more HP (what little is given), and improved MPG (as long as your not heavy on the foot). Also, you buy one replacement filter that lasts almost a lifetime saving you on having to pay each and every other oil change on your throw away filter.
Here is a test showing the results of each filter, and really wanted the Apexi filter but they only make them for Lancers and hi performance cars.
http://mkiv.com/techarticles/filters_test/2/index.html
anyone have comments?
Old May 30, 2008 | 05:35 AM
rtrackr99's Avatar
Default RE: HKS Air Filter? Lancer OEM dimensions?
You can run the part numbers and compare.
But I've read that
the 2008 Lancer and 2007+ Outlander have the same air box/filter.
("Works" has a high performance filter for the Outlander.)
The position
of the intake system seems slightly different though...
Did you see the Weapon R intake that another Outlander owner installed?
Check the previous posts...
Good luck!
E
Old May 30, 2008 | 01:52 PM
07outty's Avatar
i have '07 outlander xls and '08 lancer gts.
i have the same WORKS air filter in both.
they are pricey but................
i picked up 2 mpg crusing freeway @ 75 mph with the lancer.
have not "cruised" the outty enough yet to notice a mpg gain
both felt more low end grunt with the high flow filter.
could really notice it on the lancer with the 5 speed manual and tiny motor !
Old May 30, 2008 | 08:15 PM
rtrackr99's Avatar
Hey "07outty",
Did you ask WORKS if any more products will be listed for the 07+ Outlander?
Maybe an exhaust or ECU/Tuning Reflash?
Here's the link for the air filter.
http://www.worksevo.com/store/produc...roducts_id=486
Take care,
E
Old May 31, 2008 | 08:48 PM
07outty's Avatar
......WORKS has no other perf. stuff for the outlander.
the air filter is just a coincidence ,as they designed it for thr lancer/ evo x...........
Old Jun 1, 2008 | 02:09 AM
rtrackr99's Avatar
Aww...
I wish that WORKS would have at least made an exhaust package for the Outlander.
I also forgot to ask,
how does yourOutlander engine sound with the new hi-perf air filter?
Hope it sounds good!
Thanks!
E
Old Jun 1, 2008 | 08:35 PM
07outty's Avatar
..with the hood raised i could deffinetly tell i had changed something.
but once the hood is lowered ,can not really hear much difference
Old Jun 2, 2008 | 01:53 AM
rtrackr99's Avatar
Thanks but...
What about during wide open throttle (WOT)?
No difference in engine sound?
Aloha!
E
Old Jun 2, 2008 | 11:15 AM
willowpeak's Avatar
Hi.. I just ordered one on Friday. Any difference on performance wise? Any gains on stepping on the gas or climbing up hill on the freeeway? The filter was pretty pricey after shipping and tax. Too bad K&N doesn't have one for the newer outtie yet. Hope to hear some feeback on this WORKS filter.
Old Jun 2, 2008 | 02:24 PM
rtrackr99's Avatar
Hey "WillowPeak",
Thanks for ordering the Works filter,
maybe you could give us a review after you've finished the install?
I'm still looking forperformance muffler too.
Any other parts youare willing to mention that were installed on your Outlander?
Thank you,
E
