Horn Chirp/Honk when Lock the car by Keless remote
Old Aug 19, 2014 | 03:00 AM
Outlander78's Avatar
Default Horn Chirp/Honk when Lock the car by Keless remote
Hello every body,
I want to ask if this feature is available in all Outlander model 2011
I have outlander model 2011 3.0L with keyless entry key
if it can be enabled, what are the instructions for activating this feature in the car
Aprreciate your Help
thank you
Old Aug 19, 2014 | 09:07 AM
ccernst's Avatar
double click the lock button...it'll chirp then.
Old Aug 19, 2014 | 10:17 AM
Claude_A's Avatar
Yes.
In my 2010 manual the procedure is on page 3-11
If it does not work first time try again to get your timing right on the button press / button release section.
Old Aug 19, 2014 | 11:27 AM
Thank u for your help
The problem is my manual didn't mention any thing about horn setting or number of flashes when pressing on lock
From your forum I found instructions regarding number of flashes setting and it did work
So I thought I can get settings for horn chirp setting
If any one knows ...please tell me the procedure
Old Aug 19, 2014 | 12:03 PM
Vadimus's Avatar
Do you have stock navi? If so, you can do it in Equipment menu.
Old Aug 19, 2014 | 09:24 PM
I don't have stock Navi. I just have the smart keyless system and cruise control
Old Aug 20, 2014 | 07:03 AM
Claude_A's Avatar
To do it with the FAST key fob. (Probably the same with the regular key)
I just did it.
Ignition need to be at OFF
Headlight stalk need to be at off (not auto but OFF)
Driver door opened.
On the fob
press on the lock button (the lock will work) and while pressing count 5 seconds (5 steamboats) then while still holding on lock, press on unlock for about 4-5 seconds.
Release the unlock button first then the lock button, the car will chirp once to confirm no horn confirmation.
It does that because no setting was recorded in the system.
Now do it again to move to the setting you need.
Since you want the horn confirmation, you immediately redo the same sequence and the car will chirp twice to indicate the horn confirmation is on.
If you do it a third time you will get 4 chirps indicating you will have to press lock twice within one second to get horn confirmation.
This is the sequence the book is writing about.
Reset your light stalk to auto if it was there before.
Get out (you need to do this from outside the car)
Close doors.
Try locking using the fob you shoulds get horn confirmation (I did)
Old Aug 21, 2014 | 01:20 AM
Hi Claude_A
I tried the above instructions, it is not working... when I press Lock button and Door is open I dont hear the Lock relays and nothing happen, when I go a head and perform the the rest of instructions I dont hear any chimes or chirps,
but when releasing the Lock button first then Unlock button, this will change the door lock setting.. which is the choice of opening Driver's Door lock only, or all doors
I
Old Aug 21, 2014 | 07:01 AM
Claude_A's Avatar
You have to release the unlock first then the lock.
if you do it the other way like your are saying you change the door unlock mode as you noticed.
What country are you in? Sometime systems are different country to country.
Old Aug 21, 2014 | 10:34 AM
I m staying in UAE car is GCC specs
I feel the etacs is locked or feature is disabled. But what encouraged me to try is the alarm horn is working normally
I will try to ask dealer although I know their answer is ready!
