How can I fix a P1320 on a 2008 Mitsubishi Outlander XLS V6?
Old Nov 2, 2019 | 02:31 PM
SERPENTOR's Avatar
Default How can I fix a P1320 on a 2008 Mitsubishi Outlander XLS V6?
How can I fix a P1320 on a 2008 Mitsubishi Outlander XLS V6? It has 128,000 miles, I went to turn on my car this morning and it displayed a Service Engine Soon Light. Went to Autozone they pulled a P1320 Code "ASE certified master technicians have seen this issue on your type of vehicle and the most likely solution is: Replace Engine Control Module (ECM)" How much should a mechanic charge to fix this? Do any ECMs come with a lifetime warranty? I had a Mitsubishi Dealer Replace the ECM two years ago.
Old Nov 4, 2019 | 01:28 PM
binzd's Avatar
Default other things that can cause P1320
what about the other 2 possible causes? also if the ECM can't retard the timing far enough, why is it pre-detonating in the first place?
P1320 Ignition Timing Retard Insufficient
MITSUBISHI Possible Causes
  • Faulty Thermostat
  • Faulty Engine Coolant Temperature (ECT) sensor signal
  • Faulty Engine Control Module (ECM)
Causes of Pre-Detonation
Lean Air/Fuel Mixture. A rich Air/Fuel Mixture runs cooler than a lean mixture. ...
Too Much Compression. Compression causes heat. ...
Engine Overheating. ...
Low Octane Fuel.
I mean just a thought before chasing down used ECM's or spending 1000's only to have the same issue?
Old Nov 4, 2019 | 04:21 PM
SERPENTOR's Avatar
After two days the Service Engine Soon Light has gone away. Should I not worry anymore? The light has gone off so does that mean it is not a serious problem? Could it have been a fluke glitch and now it has fixed itself therefore the light turned off? What would you do in my situation?
Old Nov 4, 2019 | 04:35 PM
binzd's Avatar
run a tank of premium is a low cost option and monitor,
you could have just been getting serious engine knock due to cold or other external factors and now it's doing ok
Old Nov 5, 2019 | 04:57 PM
SERPENTOR's Avatar
OK thank you man should I Run Premium Shell, Exxon or BP?
Old Nov 6, 2019 | 10:19 AM
binzd's Avatar
I have not used Shell since I worked at their stations as a teen (when full service was still a thing) but the Exxon or BP are both fine or at least they were when I lived in the midwest
Old Nov 7, 2019 | 11:19 AM
inuvik's Avatar
I'd dump a bottle of Techron fuel cleaner into it and give it some "spirited driving". We've had a few instances over at the Mirage Forum where members have gotten the Service Engine Soon Light has come on with similar codes and adding a bottle of quality injector cleaner has eliminated the problem. It seems to happen after about 110k miles and about every 100k. On the Mirage Forum we have a member that has over 300k miles on his Mirage and he's had this type of error pop up that after running a tank with Techron, he's good for another 100K+.
Old Nov 7, 2019 | 11:48 AM
binzd's Avatar
I use the Techron from Chevron probably 60% of the time as there's a station a few blocks away. I think that's good advice to run a cleaner through as removing deposits helps keep the compression level down and thus prevents the pre-detonation that the ECM cannot dial back far enough.
SERPENTOR
Apr 10, 2019 10:24 AM
ukrkoz
Aug 9, 2015 09:50 PM
carsnewstoday
Dec 4, 2012 10:21 AM
mitsu08
Nov 3, 2012 09:00 PM
