How to connect Chirp Buzzer for lock\unlock tone
Old Feb 27, 2013 | 06:14 AM
firebirdrc's Avatar
Default How to connect Chirp Buzzer for lock\unlock tone
My car is not equipped with the Theft Alarm systemso I have no tone when locking\unlocking the doors using the remote control buttons (regular key not the keyless)
I want to had a Chirper to my car and I already got a simple buzzer. (see bellow)
Right now:
locking the doors:
mirrors are folded automatically and the turn signals blink once.
unlocking the doors:
mirrors are open and the turn signals blink twice.
Is there any chance to connect such a buzzer that will chirp only when closing and opening the car.
I don't want it to chirp each time I am driving and using the turn signals or when I am using the Hazard button.
Your help is much appreciated.
Old Mar 1, 2013 | 10:21 AM
firebirdrc's Avatar
bump!
Old Mar 8, 2013 | 02:42 PM
Gen-8's Avatar
Just out of curiosity try connecting it through a fuse to your turn signal wiring in the bonnet for a test. It may work as its a 12v pulse.. Let me know
Old Mar 8, 2013 | 02:50 PM
firebirdrc's Avatar
As far as I know there is no fuse for turn signal under the bonnet. Do you know which fuse is it?
Old Mar 8, 2013 | 10:37 PM
Gen-8's Avatar
Just put a fuse on the positive wire to the chirper and then put indicator on and simply touch the red chirper wire to the green indicator wire. I think it's green, there's a black and a green. Black is GND
Old Mar 9, 2013 | 09:19 AM
firebirdrc's Avatar
this is my fuse box under the hood, to which wire you think I need to hook up?
Old Mar 9, 2013 | 02:52 PM
Gen-8's Avatar
None.. Get a blade fuse, solder wire on 1 side then the buzzer red on the other and earth the buzzer black and probe the fused wire into the turn signal wiring by bulb
Old Mar 11, 2013 | 06:19 AM
pinman's Avatar
Would the buzzer not keep working when your using turn signals??
Gazza
Old Mar 12, 2013 | 02:05 AM
Gen-8's Avatar
Yes in theory but I simply want to test at the circuit will work,that is all then if so then clip the pulse further in the loom..but just thinking bout at,ours has a beep unit under the rear bumper does yours not hav it. That's how it lets us know lock v unlock with the flashes
Old Mar 15, 2013 | 06:45 AM
firebirdrc's Avatar
gen8,
just to clarify:
You want me to find the turn signal under the driver kick panel and then to connect the buzzer in order to see if it will work?
assuming that this will work, (i can't find any reason why it won't work) how I will avoid the beeping when I turn or Hazarding
where Is you beep unit located under the rear bumber? can you picture the plug & the location? maybe i will find there a blank plug that I can connect the buzzer to it.
