How to Connect iPod To Rockford Audio System
Old Jan 13, 2011 | 02:40 AM
rockzcm's Avatar
Default How to Connect iPod To Rockford Audio System
Hi
I got the outlander vrx 2.4 model and i live in Auckland. The manual advise that I can connect my iPod to rockford audio system via a genuine dock connector from Apple Inc.
I tried to use my normal USB cable that I normally use to connect my iPod to PC but it doesn't work. When i switch to iPod mode, it says no songs.
Do I need a special cable to connect iPod to the rockford system? Any advise will be appreciated
I also has an Iphone4. Does it works the same as the iPod?
Old Jan 13, 2011 | 06:06 PM
Airedog's Avatar
I pretty much just duplicated your post.
https://mitsubishiforum.com/forum/sh...ad.php?t=38217
We have an '11 2.4 with a 3rd row seat and "sight and sound" -moonroof/RF stereo.
I could only get our 8gb nano c.2005 to load and not an older 4th gen iPod with click wheel (40gb), nor a 80 gb 6th gen.
I'd be happy to stick with just the nano, but the girl has it with her. I have 22 gb of music on the 6th gen and it does not load.
Let see if together we can find an answer.
Old Jan 14, 2011 | 05:31 PM
rockzcm's Avatar
Updated News.
I tried my old iPod. I think it is the 3rd generation. It works perfectly fine but not my iPhone4, which is a shame.
Old Dec 1, 2011 | 03:47 PM
JAMESBRANTON's Avatar
Hi
I am new to this forum and am buying a 07 Outlander with the subwoofer rockford fosgate system. I would like to connect my Ipod Touch and be able to control it from the stereo unit. Is this possible with the stereo as it is or can I buy an adapter to do this?
Thanks in advance.
James
Old Dec 4, 2011 | 02:07 PM
atx25rs's Avatar
does it have the usb drive? if so it should wokr, but depending on the unit you will have to update the firmware for the stereo. I have a Outlander sport and when i connected anything with iOS4 it would fail. updating the firmware on the stereo let it connect ios4 and ios5
Old Feb 23, 2012 | 04:19 PM
Juaneme63's Avatar
Hello! I have an 09 Outlander XLS with the Rockford Fosgate System (Sun&Sound). It has an auxiliary input, however I saw the newer Outlanders seem to use the same head unit and have a USB port in the center console. Does anyone know how I can do a retrofit to add a USB port to my radio? Thanks!!!
Old Feb 23, 2012 | 07:28 PM
ivanz's Avatar
You need a new NAV unit ($1500) and bluetooth module ($300) along with some custom wiring.
Old Feb 24, 2012 | 09:50 AM
Juaneme63's Avatar
Thanks buddy! Does anybody know a less expensive solution? I am hoping for an interfase that plugs in the back of the head unit and can be found at Radio Shack...
Old Feb 24, 2012 | 11:45 PM
ivanz's Avatar
You could always buy the MITO-02 and steering wheel control interface and install your own stereo.
As far as I know, only the older MMCS in Australia has a DIN style connector in the rear for which an iPod adapter can be used for.
seandevlin
Jun 11, 2022 03:00 PM
mitsu2015
Mar 19, 2015 08:15 AM
Idz21
Jul 1, 2014 07:42 PM
Musi_oci
Jul 27, 2009 02:24 PM
dtinsley
Sep 25, 2007 09:56 PM
