How do I remove the cover for the Auto Shift ?
I have a 03 Outy with a 4 spd Auto.
The lights on the dash indicator don't work anymore when I go into Drive. They still work for P,R and N. I can't up or down shift either. I heard that next to the shifter, under the cover, a ground wire may have come loose. How do I remove that panel to access the wiring? Any help appreciated. Thanks. |
Very carefully...
Here are some pics from an 07. Hopefully they will be some help to you. I am sure it is different, but that basics are probably similar. http://www.medinacountypc.com/1.png http://www.medinacountypc.com/2.png |
Perfect - Its similar enough to be a good guide. Thanks
