How to remove cabin filter?
Old Oct 12, 2005 | 01:15 AM
Jewelz's Avatar
Default How to remove cabin filter?
Can someone please explain? Thanks.
Old Oct 12, 2005 | 01:02 PM
JMC's Avatar
JMC
Default RE: How to remove cabin filter?
I think It's inconvieniently located behind the glove box. You have to
remove said glove box to get to it. If you are mechanically inclined and
have never done it, set aside about 2 hours. After the first time, maybe
5 minutes. Or just have the dealer do it when you go for a tune up.
Old Oct 16, 2005 | 08:33 PM
Joel_CA's Avatar
Whether mechanically inclined or not, it should take no longer than 5 minutes. The glove box pops out in a few seconds once you unhook the side stops. From there, you'll see a rectangular shaped section in the heater (hvac) unit with 2 phillips screws on each end. Remove the screws then pull out the filter. Its going to look NASTY!! Button it back up by reversing the above steps.
Joel, CA
Old Oct 16, 2005 | 08:35 PM
Lil red's Avatar
Can you buy one from an autoparts store or is that a stealership kinda thing?
Old Oct 17, 2005 | 12:26 PM
JMC's Avatar
JMC
I got mine from the Dealer.........
Old Oct 17, 2005 | 06:38 PM
Lil red's Avatar
Whatca got and how much did it run you?
Old Oct 18, 2005 | 12:11 PM
JMC's Avatar
JMC
I just asked for a replacement filter and they gave it to me no charge....I get pretty hooked up with things like this at the dealer I go to.
Old Oct 19, 2005 | 05:05 PM
outlancer's Avatar
i only see three screws and from their im lost. is the box that yall speak of right in back of the glove box. or do you have to disconnect the levers and then open the box. Also why do they call it a glove box when no one carries gloves, and why a box, it is not even the right shape
Old Oct 20, 2005 | 12:09 PM
JMC's Avatar
JMC
Hahahahaa......
Wait, who said just 5 minutes?
OutlanderGT
Mar 4, 2014 04:55 PM
lolofson
Nov 1, 2013 12:33 PM
2k1monterosport
May 16, 2011 12:26 AM
Tony123
Jan 27, 2011 07:50 AM
Biggles
Jul 30, 2006 07:50 PM
