Hands Free Passcode reset procedure
I have a 2011 Mitsubishi RVR (Outlander Sport) and I was able to reset the passcode using the "hang-up switch" procedure but only after finding the following pdf documents online which describe the procedure in more detail.
Here's the text: The 4-digit passcode set by security function can be erased by operating the hang-up switch. 1. Turn the ignition switch to the "ON" or "ACC" position, and check if the radio and CD player, or the multivision display is activated. 2. Check that the hands free cellular phone system is not in voice recognition mode. 3. Press and hold the hang-up switch for approximately 2 seconds (1.5 seconds or more). 4. Within approximately 10 seconds after performing step 3, press and hold the hang-up switch for approximately 2 seconds (1.5 seconds or more) twice again. NOTE: Even if the passcode is erased, guidance such as voice guide is not provided. 5. After the operation, check if the lock with the passcode is unlocked. If the lock is not unlocked, repeat from step 2. jump straight to description of how to fix: see page 54A-574 of following pdf: http://evoscan.com/manuals/EvoX/10_G...02600C-54A.pdf How I found the ##%#%^$%#%&$%^&%!!!! document: 1. found a link to the following document http://tagore.drivingforceauto.com/s...tsb1254012.pdf see page 29 table 13 HANDS−FREE SYSTEM ASKING FOR A PASSCODE Technical Service Bulletin TSB−12−54−012 HANDS−FREE SYSTEM (BLUETOOTH/FUSE) INSTRUCTION GUIDE AND DIAGNOSTIC STEPS 2. searched for "Group 54 − Chassis Electrical" 3. found the pdf in 3 separate downloads: http://evoscan.com/manuals/EvoX/10_G...02600A-54A.pdf http://evoscan.com/manuals/EvoX/10_G...02600B-54A.pdf http://evoscan.com/manuals/EvoX/10_G...02600C-54A.pdf |
I have just gotten a 2014 Mirage the hands free is saying "security code enabled please say pass code". I have attempted to do the unlocked and nothing so far. I am a home health nurse and need to have hands free enabled. I can't get setup to start till passcode.
Originally Posted by Sergy
(Post 223339)
Hello.
My friend is in difficult situation: he has installed the password for factory Bluetooth system and forgot it. :( Delaer doesn't knowhow to remove it. Somewhere in web we found the instruction: press and hold 2 sec "hang-up" button then pause then hold 2 sec twice again. Don't work. :( Help please. Thanx in advance. PS:I mean passwordfor access to bluetooth setup menu. NotPIN-code for phone connect. I did that exactly and it unlocked it first time. Hope this helps some. |
How to unlock Bluetooth setting
For this issue you must press and hold down the map key and setting to for 4 seconds and after all you enter to the setting page and you can unlock the passcode
Originally Posted by hermancare
(Post 283122)
Sergey
Turn on the system and without touching any other buttons press and hold the hangup button for 2 seconds, release it, press and hold the hangup button for 2 seconds, release it, then press and hold the hangup button for 2 seconds and release it.All this must be done within 10 seconds. In other words you must press and hold the hangup button for 2 seconds three separate times within 10 seconds. If it doesn't work, turn off the system, turn it back on and try again.. The person I spoke to said it may take several attempts to get it to work. Good Luck... |
Reset password
This worked for me, standard radio, no touchscreen.
1. Ensure power is OFF for the radio. 2. Press and release the following buttons in this order 1 RPT, << SEEK, SEEK >>, 4>> 3. The words HFM DIAG should appear on the screen. 4. Press and release the SEL button. 5. Hold down the SEL button for a long time(about 5sec). 6. Disable the passcode If this does not solve your issue, or you have additional questions, please feel free to contact us at 1-888-702-4100. We are available Mon-Fri, 7am-8pm CT. |
This worked for me.
This worked for me.
Originally Posted by P00chie76
(Post 338344)
This worked for me.
1. Ensure power is OFF for the radio. 2. Press and release the following buttons in this order 1 RPT, << SEEK, SEEK >>, 4>> 3. The words HFM DIAG should appear on the screen. 4. Press and release the SEL button. 5. Hold down the SEL button for a long time(about 5sec). 6. Disable the passcode If this does not solve your issue, or you have additional questions, please feel free to contact us at 1-888-702-4100. We are available Mon-Fri, 7am-8pm CT. Step 6. How do you disable the passcode? |
| All times are GMT -5. The time now is 09:08 AM. |
