How to unlock MMCS
#464
Hey, any chance you could send me a link with the parts I'd need to connect my hard drive to my computer? Also wondering what country are you from?
#466
lol Vadimus
I am from JAMAICA....
It would be easier you got a laptop that uses IDE hard drive. In any case if your connecting it to a desktop's IDE bus you will need an adaptor to convert the laptop size hard drive to the desktop bigger IDE bus.
Then after unlocking you will need a IDE(laptop size) to USB to do your backup and other file transfers:
Amazon.com : 2.5" to 3.5" Laptop IDE Hard Disk HDD Adapter : Desktop Computer Internal Hard Drives : Computers & Accessories
#467
It would be easier you got a laptop that uses IDE hard drive. In any case if your connecting it to a desktop's IDE bus you will need an adaptor to convert the laptop size hard drive to the desktop bigger IDE bus. Amazon.com : 2.5" to 3.5" Laptop IDE Hard Disk HDD Adapter : Desktop Computer Internal Hard Drives : Computers & Accessories
Amazon.com: USB 2.0 to IDE/PATA 2.5" Hard Disk Drive HDD Aluminum External Case Enclosure 500GB Max Capacity: Computers & Accessories
#468
yes
Thanks so much very helpful indeed. The second link to the "USB 2.0 to IDE/PATA 2.5 "Hard Disk Drive HDD Aluminum External Case Enclosure 500GB Max Capacity." This is just a case enclosure? $6.25? Do I place the HDD inside it to connect to the pc? I'm for New Zealand Btw
NB. I would suggest you use a linux OS to access folders because if you use windows it will create $RECYCLE folders on your drives which can be seen in linux I don't know if those folders cause any harm but I am just extra carefull I always return and delete those on my linux if I made mods using windows.
