How to unlock MMCS
Old Dec 19, 2013 | 07:47 AM
  #461
Chucki Berry's Avatar
I have tried and its saying the samething "Program can't be found, check dvd drive". Anymore ideas?
Old Dec 19, 2013 | 07:52 AM
  #462
Vadimus's Avatar
Not at the moment. I will try to switch my N version to J to check all the issues.
Old Dec 19, 2013 | 09:03 AM
  #463
It would be really appreciated if you could and probly try a start up disk thats working and suggest in the mean time I will continue to sing to myself
Old Dec 20, 2013 | 03:41 AM
  #464
iJustinz's Avatar
Smile
Hey, any chance you could send me a link with the parts I'd need to connect my hard drive to my computer? Also wondering what country are you from?
Old Dec 20, 2013 | 06:37 AM
  #465
Vadimus's Avatar
He ignores Location part of forum user profile just like you do iJustinz
Old Dec 20, 2013 | 08:24 AM
  #466
Talking lol Vadimus
I am from JAMAICA....
It would be easier you got a laptop that uses IDE hard drive. In any case if your connecting it to a desktop's IDE bus you will need an adaptor to convert the laptop size hard drive to the desktop bigger IDE bus.
Amazon.com : 2.5" to 3.5" Laptop IDE Hard Disk HDD Adapter : Desktop Computer Internal Hard Drives : Computers & Accessories Amazon.com : 2.5" to 3.5" Laptop IDE Hard Disk HDD Adapter : Desktop Computer Internal Hard Drives : Computers & Accessories
Then after unlocking you will need a IDE(laptop size) to USB to do your backup and other file transfers:
Amazon.com: USB 2.0 to IDE/PATA 2.5" Hard Disk Drive HDD Aluminum External Case Enclosure 500GB Max Capacity: Computers & Accessories Amazon.com: USB 2.0 to IDE/PATA 2.5" Hard Disk Drive HDD Aluminum External Case Enclosure 500GB Max Capacity: Computers & Accessories
Old Dec 21, 2013 | 04:38 AM
  #467
iJustinz's Avatar
Smile
It would be easier you got a laptop that uses IDE hard drive. In any case if your connecting it to a desktop's IDE bus you will need an adaptor to convert the laptop size hard drive to the desktop bigger IDE bus. Amazon.com : 2.5" to 3.5" Laptop IDE Hard Disk HDD Adapter : Desktop Computer Internal Hard Drives : Computers & Accessories
Thanks so much very helpful indeed. The second link to the "USB 2.0 to IDE/PATA 2.5 "Hard Disk Drive HDD Aluminum External Case Enclosure 500GB Max Capacity." This is just a case enclosure? $6.25? Do I place the HDD inside it to connect to the pc? I'm for New Zealand Btw
Old Dec 22, 2013 | 08:50 AM
  #468
Default yes
Yes, use the enclosure once you have unlocked the HDD to connect to your computer then you will be able to see the drives.
NB. I would suggest you use a linux OS to access folders because if you use windows it will create $RECYCLE folders on your drives which can be seen in linux I don't know if those folders cause any harm but I am just extra carefull I always return and delete those on my linux if I made mods using windows.
Old Dec 22, 2013 | 08:51 AM
  #469
Default iJustinz
iJustinz what exactly are you trying to do with your system? is it a japanese model?
Old Dec 22, 2013 | 09:42 AM
  #470
Vadimus's Avatar
No harm from those Recyler folders.
