How to unlock MMCS
Old Nov 24, 2012 | 08:17 AM
  #361
firstnc's Avatar
Originally Posted by ceka
I have updated 2010A m190 map in my Outlander. The update was made following your directives guys. Thanks a lot.
But the map little outdated, I'd like to have a new one. There are a lot new and better roads but they aren't in the navi's database.
Is there a new (2012 or sg like that) map?
new: I found something. They say that it's 2011 map. "For those who want new maps (2011), we can get it here: http://fileshare.mindbit.ro/alex/ (User: mitsu, Pass: 1qaz2wsx)" I downloaded it but it's just a 2010 m190 map too.
Is there 2012 map available?
Do you have a download link for that?
Thx a lot
new and latest info:
"M190 are last available at that moment, we are waiting for new maps too"
This link is only the map???
Is it possible to have the image for EU unit?
I am in a big trouble
thanks guys
Old Nov 24, 2012 | 12:34 PM
  #362
codetrap's Avatar
Thx a lot
I purchased and shared the DVD. I finally found a large file hoster and am uploading the ISO. I'm also going to pull a copy of the map files from the unit. The map I purchased was supposed to be 2011A, but Mitsu ****ed up and put out the new part number with the 2010A map. I'm currently arguing with them that they should give me the 2011 for free.
Old Nov 25, 2012 | 11:14 PM
  #363
Lswingmio's Avatar
Default Unlocked MMCS on 2012 Lancer GTS
Hi everyone. I watched the u tube video "PLAY DVD in MOTION LANCER Multicommunication System". by klassikly. I bought the patch from Navhack for NR261um 00007004, which is my mmcs version. I used my
I MAC to download. I also downloaded Stufit 10.0.2 to use to extract the file after I downloaded. ( my I Mac is an OS X 4.10) and only the stufit 10.0.2 standard can work for it. After this I used the I Mac burner to place on the CD-R. Followiing klassiky's install intruction to the MMCS I inserted the CD to my MMCS , press update, then the second time it wanted to up date, I said NO to the update. And it works. I will make sure I didn't lose any other features tomorrow when I go to work.
TTFN
LSM
Old Dec 13, 2012 | 01:04 AM
  #364
dennishr's Avatar
ok guys...i have a question. I was able to extract HDD from MMCS ynd to put in laptop. I tried booting from CD, but it keeps asking for HDD master password.....if i force it to boot, when i start xbox linux OS, after pressing 3 and typing command to unlock it, linux says there is no master hdd attached or something like that...any clues?
edit: problem solved.
Old Dec 15, 2012 | 11:24 AM
  #365
elboy0712's Avatar
Default Did you figure this out yet?
What type of computer are you using to do this. Whats your setup.
1. Have you checked bios settings for the drive controller
2. checked drive jumpers. (its been a while since i had mine out i dont remember what the default jumper settings are as you pull it out, or even if it has one)
regardless: make sure the drive it jumpered for master and that the bios is set to have that spot on the bus as master or as cable select if you are using a laptop. bottom line you dont want it set as slave or a conflict between the drive setting and the bios setting.
also silly as this may be to have to say. but if you are using a desktop or external drive dock. make sure the power cable is plugged in.
Old Dec 28, 2012 | 02:23 PM
  #366
tochill's Avatar
Originally Posted by erikphilips
Small update to my previous post, the Intel Password Textbox is limited to 32 characters.
Well I got it working... unbelievable. I had to write a program to write the original values which are outside of human readable text to the clipboard to paste the value in the window. In order to get the correct values in the clipboard I had to use Code Page 1252 (http://en.wikipedia.org/wiki/Code_page_1252); No more using XboxHDM 2.2 !!
I have a small YouTube Clip showing it in action.
Erik,
Can you paste the password in this chat so we Can use it as well?
Thanks!
Old Dec 29, 2012 | 10:39 AM
  #367
erikphilips's Avatar
Originally Posted by tochill
Erik,
Thanks!
This probably won't work. But the password is:
߬߱*κ߱ž‰–ߪŒš - for loader version 261EM
߬߱*Ϊ߱ž‰–ߪŒš - for loader version 261UM
߰߾*ɲ‰ž–Œš - for loader version 261JM (unverified)
(notice the difference is the small o on EM and small a on EM at the 18th character)
Lets see how the website deals with extended characters. (Looks like it worked, maybe)
Old Dec 29, 2012 | 07:03 PM
  #368
tochill's Avatar
߬߱*Ϊ߱ߪ
I keep running into the same extraction issue where it keeps extracting the same file HD1. I ran the bat file attached a few posts back but have the same issue. Do you guys know what i may be missing?
Old Dec 31, 2012 | 08:58 PM
  #369
Gen-8's Avatar
Hiw do I find the password for my hdd? Mine is NR261JM 2.01 version. 00.00.46
Old Jan 7, 2013 | 03:09 AM
  #370
dennishr's Avatar
Default Firmware change UM to EM
Does anybody here know is it possible to change firmware in MMCS? i have 261 UM and i want to change it to 261EM. Any solution? any Image file or something?Thanks in advance
