Info on the outlanders 4wd system
Old Dec 17, 2008 | 07:57 AM
chenarm's Avatar
Default RE: Info on the outlanders 4wd system
This is taken out of the Outlander service manual
"As the vehicle is intended for on-road use, long-time driving on a sandy or slushy road must be avoided. When the vehicle is driven on a sandy or slushy road for a long time, the fail-safe function of the electronic control 4WD system tends to enter the protective control mode which switches the control from 4WD to 2WD gradually in order to protect the drive system, and the indicators ("4WD" and "LOCK") tends to illuminate"
If you are looking for an offroad vehicle you might be better served by something else.
Old Dec 17, 2008 | 09:05 AM
mitsupartsman.com's Avatar
ORIGINAL: jsrd
ORIGINAL: rcpax
Wow, that would probably cost like 1/4 of your car if done aftermarket. I think it's possible IMO, but at what cost?
You are right rcpax, the cost would be a factor to consider … perhaps, is better to wait to have the version 4WD in Mexico. . .
just for the transmission, transfer case and rr differential; $7,500.00 then you would need everything else inbetween.
finding a good donor car would make this project doable.
Old Dec 17, 2008 | 09:44 AM
boon4376's Avatar
Thanks chenarm, I guess that settles it for me.
Old Dec 17, 2008 | 11:40 PM
jsrd's Avatar
ORIGINAL: mitsupartsman.com
...just for the transmission, transfer case and rr differential; $7,500.00 then you would need everything else inbetween. finding a good donor car would make this project doable.
Thank's for the information mitsupartsman, but really, is better to me to wait that 4WD version arrives to Mexico, before that to try to make the 'update'. . .
Old Dec 18, 2008 | 01:33 PM
n0c7's Avatar
Are there any ill effects of using 4WD and/or 4WD lock on dry pavement, especially while turning like traditional locking differential 4X4's have?
Old Dec 18, 2008 | 02:22 PM
rcpax's Avatar
AFAIK, the manual discourages using 4WD Lock mode on dry pavement, saying something about premature tire wear and also added wear to the 4WD system. I just leave it on to 4WD Auto most of the time, and I switch to 2WD when making long freeway trips with the cruise control on.
Old Dec 18, 2008 | 08:13 PM
tdford's Avatar
No it will not do damage like a locking differential 4wd system would. The Outlander's is electronic, and the Auto and Lock mode act more like a All-Wheel-Drive system. The system will even shut down or reduce power to the rear if it is overheating.
This has been talked m-a-n-y times though...
Old Dec 18, 2008 | 08:19 PM
n0c7's Avatar
ORIGINAL: tdford
That's what I thought, but if the search worked on here again I could find that info. Where's Sebba? He's been quiet since the search broke.
Old Dec 19, 2008 | 11:02 AM
rcpax's Avatar
ORIGINAL: tdford
The reason I said this is that 4WD Lock on dry pavement will definitely ruin your tires prematurely, increase your fuel consumption, and create more noise. Now, common sense will dictate that if the wheels are creating more wear to the tire, the 4WD system that rotates the wheels is put under greater stress.
Old Dec 19, 2008 | 11:04 AM
rcpax's Avatar
And notable too that "tight corner braking" phenomenon is only observe in 4WD Lock mode and not in 4WD Auto or 2WD.
