Installing Amp
Old May 12, 2006 | 03:42 AM
90eclipse_gs's Avatar
Default RE: Installing Amp
take the dash apart and there should b screws holding the dash kit for the factory deck and there u go but when puting in a new deck ull have to buy a WIREING HARNESS and DASH KIT for that car.
UNLESS IT HAS TWO HOLES LIKE :[___]: LIKE THAT AROUND THE FACTORY DECK THEN ULL NEED TO GET THE SPICIAL KEYS THAT FIT IN THERE TO GET IT OUT"
Old May 12, 2006 | 01:03 PM
BeezSK's Avatar
i figured the dash has to come apart, I was looking for something a little more descriptive.
Old May 16, 2006 | 06:03 PM
Jewelz's Avatar
where is this hole underneath the drivers seat? Does the seat have to come out? I've been trying to find this hole.....
Old May 16, 2006 | 06:27 PM
dirtwagon's Avatar
The hole is not under the seat, it is at the base of the firewall on the driver's side.
"hope this helps, if you are talking about coming from the engine through the firewall, if you pull the carpet back under the driver side front, you should see a small perferated circle, peel that back and you can drill right there, thats where i drilled to run my amp power to the battery"
This was scalped from another topic and the info was posted by drh.
Old May 23, 2006 | 12:50 PM
drh's Avatar
drh
ok ok so its been awhile since ive been on.. life has been way busy.. if any one needs it email me and i can take some pics of my install.. everything is still messy under my seats, I havent taken the time to tie the wires together, but hey who cares when you got sound right? Anyways email me at danielhii@msn.com. Ive installed a 200w 4ch alpine to my new door speakers, cut the tweeters out for now until i can afford a component set that I want. I installed 2 12" subs inside a bypass box, a 2ch 400 watt dual(cheap amp) but it does plenty for these subs. new JVC head unit with USB interface on the front, recently installed the IPOD interface that lets me Control my ipod through the Head unit. Ill take pics of everything I can.
Old May 23, 2006 | 08:00 PM
BeezSK's Avatar
drh, email me pics and I'll host them on my webspace for you
Old May 24, 2006 | 01:05 PM
BeezSK's Avatar
pics are here http://beezsk.com/drh/
fiestataz
Oct 14, 2011 09:17 AM
CarlisleP&SPaddy
Jan 26, 2010 10:32 AM
BrianWSNC
Oct 16, 2008 08:22 AM
50ul }{4ck3r
Mar 25, 2008 12:49 PM
