Installing ground wire(5)
Old Feb 11, 2006 | 09:45 PM
  #21
dirtwagon's Avatar
Default RE: Installing ground wire(5)
I cannot see all the grounding points in the pics.
Old Feb 13, 2006 | 07:27 PM
  #22
JMC's Avatar
JMC
You might be able to get a better picture from the people that make the wires. I'd contact them and let them know what you want to do.
Old Feb 13, 2006 | 11:22 PM
  #23
wicked_outlander's Avatar
ORIGINAL: JMC
It make you smile that much more! Don't make me get the Chief on you! Hahahaha...
cheif aint here...lolz
Old Feb 13, 2006 | 11:31 PM
  #24
ORIGINAL: dirtwagon
dude, follow the path were all silver wires at.....check this out, you gotta have 5 points k? heres the points:
1.negative battery clamp (connect wire / wires to post )
2.from negative post to engine block
3.from negative post to left ground wall ( body)
4.right ground wall (body) to throttle body
5.throttle body to rear wall (replace stock ground wires, throttle section)
Old Feb 14, 2006 | 01:21 PM
  #25
JMC's Avatar
JMC
That's perfect........we should use that with some high res pictures!
Old Feb 14, 2006 | 07:04 PM
  #26
dirtwagon's Avatar
I see...I thought that they would all come off of the negative terminal. I will follow your recommendations, thanks! Good fun for my days off. Damn, I spend more time on this car than my Camaro when I had it. That's not good....my Camaro could have wiped my Outlander before getting into second gear. In any case, I have seen noticeable differences with the minor mods I do have. We all start somewhere.[&o]
Old Feb 19, 2006 | 10:21 PM
  #27
you can also install extra wires, i.e. tranny ground system, ignition ground path and neg. battery post ground sys.
DylanRobles
Mar 8, 2012 02:35 PM
silverspyder
Oct 6, 2006 10:21 AM
expositor
Jul 23, 2006 04:34 PM
faded2
Jan 19, 2006 08:43 AM
blamesociety
Dec 16, 2005 09:14 PM
