Installing new battery 2005 Outlander
Old Oct 26, 2012 | 01:11 PM
BrianB's Avatar
Default Installing new battery 2005 Outlander
Is there anything I need to know when install a new battery onto an 2005 Outlander, I understand I have to disconnect the neg side first, then replace the Pos side first when installing.
The hand book mention about the gear shifting may change at first, want is meant by that?
Thanks
Brian
Old Oct 26, 2012 | 05:21 PM
Elisha's Avatar
The transmission adapts to your driving style. So basically if you have a lead foot, it upshifts at a higher rpm.
So when you disconnect your battery, you reset that saved profile and it has to re-learns your driving habits.
So basically if you feel it's not as peppy as it used to be after a battery change, just give it a few days and drive as you usually do and it will re-learn!
Old Oct 26, 2012 | 05:52 PM
BrianB's Avatar
Thanks Elisha,
Appreciate the reply.
Brian
Old Oct 26, 2012 | 06:17 PM
Elisha's Avatar
No problem!
Old Oct 26, 2012 | 08:37 PM
milliesdad's Avatar
You will also loose the presets on your radio, but that's easy to re-do.
Old Oct 30, 2012 | 08:50 PM
BrianB's Avatar
Installed new battery okay, never noticed any change in the gear shifting, maybe because I'm not a fast drive.
The radio preset never lost it's memory, the only thing I noticed was the trip meter went back to zero, no big deal.
Thanks again.
waid302
May 8, 2021 01:14 AM
monkeyman
Jan 22, 2013 06:36 PM
Jook
Apr 20, 2011 08:43 PM
07Outlander
Oct 18, 2007 04:44 PM
embassy17
Apr 24, 2006 06:14 PM
