Jack points Outlander PHEV 2014
Old Mar 30, 2014 | 08:40 AM
Treo's Avatar
Default Jack points Outlander PHEV 2014
Hi!
I'd like to change to summer tires on my outlander PHEV.
On my SAABs I used to lift under the motor and behind the trailer hitch with my garage jack and change two tires at the time.
But on the outlander under the motor there is just a smooth plastic casing. How would I jack up the front tires?
I guess jacking under the trailer hitch on the outlander would be OK?
The manual specifies some flimsy little jack points for the jack that came with the car but it looks like they could be damaged if I use them.
Old Mar 30, 2014 | 09:41 AM
Claude_A's Avatar
Here you go
http://mmc-autoelectric.org.ua/manua...4/index_M1.htm
Old Mar 30, 2014 | 01:59 PM
Treo's Avatar
Thanks!
I ended up lifting each front wheel by the front suspension crossmember and then lifting the back end by the trailer hitch. Worked fine!
The car is very quiet on the road now without the spiked tyres!
n0c7
Jun 5, 2013 10:38 PM
rcpax
Mar 8, 2013 12:53 PM
OTO27
Mar 8, 2013 11:31 AM
ukrcan
May 4, 2012 10:28 AM
9LIVEZ
Dec 21, 2008 02:35 PM
